ICEMCFD 2D Mesh limitation
Old   February 27, 2006, 06:15
Default ICEMCFD 2D Mesh limitation
Karsten
I am trying to generate a simple planar 2D mesh in ICEM. (icemcfd 5.1-linux)
I get an error message if i specify more than a certain number of points on one edge and the block is not meshed:
A minor internal error has occurred. You may continue to work but if problems arise they may be related to this error. Try using the check/fix function to fix the problem The following message was designed to aid developers fix the problem:
too many points in retrieve_face_info
Is there a bugfix for this error? What is the check/fix function?
Old   February 27, 2006, 22:56
Default Re: ICEMCFD 2D Mesh limitation
TB
I'm not sure but I suspect that could be sth related to the tolerance of your geometry. Is the mesh scale smaller than the tolerance you specify in geometry?
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 06:21
[ICEM] Unstructure Meshing Around Imported Plot3D Structured Mesh ICEM kawamatt2 ANSYS Meshing & Geometry 17 December 20, 2011 11:45
Importing an OpenFOAM mesh into Engrid. Is there a mesh size limitation ? ayoros enGrid 0 April 20, 2011 09:53
few quesions on ANSYS ICEMCFD and FLUENT Prakash.Paudel ANSYS 0 August 12, 2010 12:07
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 09:38
