November 18, 2019, 22:37 |
Dependence on the initial conditions
Rep Power: 11 |
I simulate a multiphase flow with continous phase for air and water. I would like to know if there may have a dependence on the initial conditions even if I run a steady state simulation ? Thank you for your help it's appreciated |
November 19, 2019, 00:43 |
Rep Power: 143 |
Yes, it is possible to have a dependance on initial conditions, even for a converged steady state run.
For example, imagine the Coanda effect in a diffuser with separation. The jet can stick to one side of the diffuser or the other and converge in steady state in either configuration. Which one it sticks to depends on the initial conditions.
chtMultiRegionSimpleFoam: maximum number of iterations excedeed. | Nkl | OpenFOAM Running, Solving & CFD | 19 | October 10, 2019 02:42 |
Free surface issues with interDyMFoam for hydroturbine | oumnion | OpenFOAM Running, Solving & CFD | 0 | October 6, 2017 14:05 |
pimpleFoam: turbulence->correct(); is not executed when using residualControl | hfs | OpenFOAM Running, Solving & CFD | 3 | October 29, 2013 08:35 |
pisoFoam with k-epsilon turb blows up - Some questions | Heroic | OpenFOAM Running, Solving & CFD | 26 | December 17, 2012 03:34 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
