Animation in CFX
Old   February 24, 2006, 05:58
Default Animation in CFX
MKP
Dear users,
I would like to animate the flow at different iterations (say, 100th,200th,500th etc.) So i saved *.bak (backup) files at different iterations. Now, How to make animation using these *.bak files.
I read in CFX-post manuals that animation is possible only in the particular *.bak/*.res files. But it does not deal with how to connect different files (*.bak/*.res) in a single animation.
Any suggestions are most welcome, thanx n advance.
M K P
Old   February 26, 2006, 03:42
Default Re: Animation in CFX
TB
Post doesn't give high quality animation anyway. I suggest you to load these bak files and then output your results in png format. After you have done this, use external software to create animation. I remember an old post by Michael Bo Hansen that give detailed info about how to do that. Try searching for ANSYS CFX community forum....I'm pretty sure he had posted a pdf link before.
Old   February 28, 2006, 02:29
Joe
Do you unnderstand correctly that you what to make an animation from steady state simulation?
Old   February 28, 2006, 20:06
TB
If the solution doesn't change with iteration loop, you will see no change in animation anyway.
Old   February 28, 2006, 22:27
Rajit
yup there is a way to connect different .res files in one animation.Need some time to refresh my memory as iam not working CFX any more.... Regards Rajit
Old   March 2, 2006, 07:03
Michael Bo Hansen
http://users.cybercity.dk/~ida3068/cfd/
Transient animation performance in CFX 5.5 POST Sjoerd Romkes CFX 8 February 5, 2013 14:53
CFX animation nuimlabib CFX 3 November 21, 2010 08:56
Vectorial animation of results in CFX attilio CFX 2 February 24, 2009 18:46
Turbulence animation using CFX anand CFX 0 July 29, 2008 05:32
Timestep value plotted in animation, CFX 5.5 POST Sjoerd Romkes CFX 7 March 5, 2002 10:34
