Extracting Post Data to a Text File
Old   February 10, 2006, 03:54
Default Extracting Post Data to a Text File
Ram
Hi
I have a rotating domain model, for which I need to extract data at each radial location. For each Radial location, I need T Total, P total, etc, in a csv format. This data needs to be extracted at a series of radial locations. Can anyone guide me with a simple CCL or Power Syntax code to extract this data.
Thanks
Ram P
Old   February 10, 2006, 09:00
Default Re: Extracting Post Data to a Text File
TB
Edit your state file, you may find some function called "Export". Use command export in command window to automate the process. Refer to user manual about command "export".
Old   February 13, 2006, 06:25
Ram
TB
Thanks for your idea. I searched the archives and found the required code to automate the process
Ram P
Old   March 3, 2006, 06:20
Bile
Hi, Ram, I have the same question. Can you show me the locaiton of the code you have found? Thank you.
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
paraview installation woes vex OpenFOAM Installation 15 January 30, 2011 07:11
how can i get transient post data file (.ccmt)? okyaoyao25 Siemens 3 December 1, 2010 05:04
Installation of OpenFOAM-1.6 on Ubuntu 9.10 marval OpenFOAM Installation 2 March 17, 2010 08:33
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
