-   CFX (https://www.cfd-online.com/Forums/cfx/)
-   -   Solver failed with a non-zero exit code of : 2 (https://www.cfd-online.com/Forums/cfx/222502-solver-failed-non-zero-exit-code-2-a.html)
Thamarai November 26, 2019 22:17
3 Attachment(s)
Iam working on fire hydrant valve to calculate the pressure loss in CFX. while running the setup iam getting an error message stating "Solver failed with a non-zero exit code of : 2"
At the inlet Mass flow rate is set as 8.5 kg/s and outlet is static pressure with relative pressure as 1 atm.
Attachment 73524
Attachment 73525
Attachment 73526
Here Iam sharing the Images for your reference.
The following is the output file which is quite lengthy sorry for that since Iam a new user dont know how to post.
| Mesh Statistics |
| Domain Name | Orthog. Angle | Exp. Factor | Aspect Ratio |
| | Minimum [deg] | Maximum | Maximum |
| Default Domain | 7.2 ! | 3870 ! | 3774 ! |
| | %! %ok %OK | %! %ok %OK | %! %ok %OK |
| Default Domain | <1 4 96 | 4 2 94 | 16 8 76 |
Domain Name : Default Domain
Total Number of Nodes = 4190009
Total Number of Elements = 9259929
Total Number of Tetrahedrons = 2360959
Total Number of Prisms = 6898970
Total Number of Faces = 1380426
| User Defined Monitor Information |
Monitor Point: Losses in Pipe
| Average Scale Information |
Global Length = 7.6804E-02
Minimum Extent = 8.7000E-02
Maximum Extent = 1.8650E-01
Density = 9.9700E+02
Dynamic Viscosity = 8.8990E-04
Velocity = 7.2786E+00
Advection Time = 1.0552E-02
Reynolds Number = 6.2630E+05
| Checking for Isolated Fluid Regions |
No isolated fluid regions were found.
| The Equations Solved in This Calculation |
Subsystem : Momentum and Mass
U-Mom
V-Mom
W-Mom
P-Mass
Subsystem : TurbKE and Diss.K
K-TurbKE
E-Diss.K
CFD Solver started:
| Convergence History |
| Timescale Information |
| Equation | Type | Timescale |
| U-Mom | Auto Timescale | 3.06234E-03 |
| V-Mom | Auto Timescale | 3.06234E-03 |
| W-Mom | Auto Timescale | 3.06234E-03 |
| K-TurbKE | Auto Timescale | 3.06234E-03 |
| E-Diss.K | Auto Timescale | 3.06234E-03 |
OUTER LOOP ITERATION = 1 CPU SECONDS = 3.365E+02
| Equation | Rate | RMS Res | Max Res | Linear Solution |
| U-Mom | 0.00 | 5.0E-05 | 1.3E-03 | 1.1E+01 ok|
| V-Mom | 0.00 | 1.9E-05 | 4.9E-04 | 2.3E-01 ok|
| W-Mom | 0.00 | 1.1E-05 | 8.0E-05 | 4.5E+01 ok|
| P-Mass | 0.00 | 1.7E-02 | 1.5E-01 | 10.1 2.8E-02 OK|
| K-TurbKE | 0.00 | 1.1E-03 | 1.0E-02 | 43.9 4.7E-01 ok|
| E-Diss.K | 0.00 | 7.8E-02 | 1.0E+00 | 12.8 1.0E-02 OK|
OUTER LOOP ITERATION = 2 CPU SECONDS = 1.303E+03
| U-Mom | 2.62 | 1.3E-04 | 2.4E-03 | 1.9E+00 ok|
| V-Mom | 1.03 | 2.0E-05 | 6.7E-04 | 5.8E-02 OK|
| W-Mom | 9.58 | 1.0E-04 | 3.1E-03 | 2.1E+00 ok|
| P-Mass | 0.03 | 4.6E-04 | 3.0E-03 | 10.1 8.4E-02 OK|
| K-TurbKE | 0.06 | 6.1E-05 | 5.9E-03 | 43.8 4.6E-01 ok|
| E-Diss.K | 0.85 | 6.6E-02 | 1.0E+00 | 39.4 1.0E-04 OK|
OUTER LOOP ITERATION = 3 CPU SECONDS = 2.197E+03
| U-Mom |32.82 | 4.3E-03 | 5.7E-02 | 5.4E-01 ok|
| V-Mom |11.44 | 2.3E-04 | 2.2E-02 | 1.6E-01 ok|
| W-Mom |36.83 | 3.8E-03 | 1.0E-01 | 5.8E-01 ok|
| P-Mass | 4.18 | 1.9E-03 | 2.5E-02 | 10.1 6.9E-02 OK|
| K-TurbKE |99.99 | 6.1E-02 | 7.0E-01 | 5.7 6.8E-05 OK|
| E-Diss.K | 0.25 | 1.7E-02 | 9.3E-01 | 12.3 1.3E-05 OK|
OUTER LOOP ITERATION = 4 CPU SECONDS = 2.966E+03
| U-Mom | 2.77 | 1.2E-02 | 2.4E-01 | 4.2E-02 OK|
| V-Mom | 5.68 | 1.3E-03 | 9.1E-02 | 1.1E-02 OK|
| W-Mom | 2.20 | 8.4E-03 | 1.4E-01 | 8.0E-02 OK|
| P-Mass | 0.75 | 1.4E-03 | 4.3E-02 | 10.1 4.7E-02 OK|
| K-TurbKE | 0.00 | 3.3E-05 | 6.2E-04 | 42.7 1.8E-01 ok|
| E-Diss.K | 0.07 | 1.1E-03 | 1.0E+00 | 13.2 5.4E-05 OK|
OUTER LOOP ITERATION = 5 CPU SECONDS = 3.810E+03
| U-Mom | 0.00 | 2.9E-05 | 1.2E-03 | 4.8E+01 F |
| V-Mom | 0.01 | 1.1E-05 | 1.1E-03 | 1.5E+01 F |
| W-Mom | 0.00 | 2.6E-05 | 1.0E-03 | 7.9E+01 F |
| P-Mass | 0.00 | 2.9E-06 | 2.5E-03 | 10.1 1.8E+00 F |
Parallel run: Received message from slave
Slave partition : 13
Slave routine : ErrAction
Master location : Message Handler
Message label : 001100279
Message follows below - :
| ERROR #001100279 has occurred in subroutine ErrAction. |
| Message: |
| Floating point exception: Overflow |
| Message: |
| Stopped in routine FPX: C_FPX_HANDLER |
| ERROR #001100279 has occurred in subroutine MESG_RETRIEVE. |
| Message: |
| Stopping the run due to error(s) reported above |
| An error has occurred in cfx5solve: |
| The ANSYS CFX solver exited with return code 1. No results file |
| has been created. |
Thank you.
