November 26, 2019, 15:01 |
Help with CFX
Rafael
Rep Power: 6 |
Hello! I'm noob with CFX. I want to simulate the air flow inside a bus when the bus is at 30km/h. However, when the simulation is complete, I open the postprocessor and add streamlines of velocity, but looks like the air isn't coming inside the bus, just flowing outside.
This is my geometry https://ibb.co/Nn6G3vn This is the streamlines https://ibb.co/x8jK349 This is my project with the geometry file https://www.dropbox.com/s/lrtfi1u2s1...OTRAB.zip?dl=0 Thank you! |
November 26, 2019, 16:44 |
Rep Power: 143 |
Streamlines are integrated from a seed point. You appear to have put the seed points on your inlet, and not much of your flow from the inlet will get inside the bus. I would recommend putting some seed points inside the bus - as points, lines or volumes which you define inside the bus; then use that object as the streamline seed point.
November 26, 2019, 17:02 |
Rafael
Rep Power: 6 |
I think I understood hahaha
So if I create domains in all windows and add streamlines starting from the windows? However I don't know how to add domains |
November 26, 2019, 17:40 |
Rafael
Rep Power: 6 |
Well, as I don't know how to see the streamlines starting from the windows (and have no idea of what to search) I'm just clicking every button I see.
Selecting "Default Domain Default" as the starting for the streamlines, I got this: https://ibb.co/LgVTbT5 Could you explain me what means to select "default domain default" at the "starting from" option? I could say that select the inlet in this option gives me the streamlines starting from the inlet, but I can't understand when I select the "default domain default". |
November 26, 2019, 21:42 |
Rep Power: 143 |
If you select a volume for your seed point (such as your domain as you have done) then it will use every node location in the volume as a seed point. But note that by default it then thins them down as there are usually zillions of nodes in a volume.
The easiest way to start a streamline exactly where you want it is to define a point using XYZ coordinates to be inside your bus. Then make a new streamline object using the point object as a seed point. But the image you show is what I would expect - flow streaming past the bus on the outside and a chaotic flow inside.
November 28, 2019, 22:08 |
Rafael
Rep Power: 6 |
I really appreciate your help, ghorrocks! I create two plans and with contours I set the plan and the variable velocity to see it! Thats exactly what I want, cause with this plans I can make a relation between velocity of the air and thermal sensation! Thank you!!
CFX Treatment of Laminar and Turbulent Flows | Jade M | CFX | 18 | September 15, 2022 07:08 |
High Resolution (CFX) vs 2nd Order Upwind (Fluent) | gravis | ANSYS | 3 | March 24, 2011 02:43 |
CFX pressure in Simulations problem | nasdak | CFX | 1 | April 14, 2010 13:22 |
PhD using CFX | Rui | CFX | 9 | May 28, 2007 05:59 |
FSI using CFX and ANSYS | Bi Chang | CFX | 2 | May 10, 2005 04:47 |
