What is Velocity U.Beta ?
Old   April 10, 2008, 19:46
Default What is Velocity U.Beta ?
Kushagra
Hi, In CFX-Post, what is Velocity U.Beta ? Thanks very much. Regards, Kushagra
Old   April 11, 2008, 09:09
Default Re: What is Velocity U.Beta ?
latslosh
As far as I know it is the coefficient used in the spatial discretisation scheme (when it is not fixed by the user). You will find .Beta outputs for variables which are included in the transport equations (e.g. volume fractions for 2 phase flow)
latslosh.
Old   April 13, 2008, 18:52
The .beta variables are used in the High-resolution differencing scheme as part of its method of minimising over/undershoots.
Old   May 20, 2020, 11:47
Default Meaning and interpretation of velocity u.beta
AH
visitor is on a distinguished road
Still can't understand the meaning of this result. I have a reading on screen on; fluid. Velocity u.Beta Volume Rendering 1
Minimum value 1e-16 and maximum value 1.0.
What does this mean in terms of m/s?
Thanks
Regards
visitor is offline   Reply With Quote
Old   May 20, 2020, 13:00
Opaque will become famous soon enough
The values of beta has no meaning from the solution point of view.
It is the coefficient used to reconstruct the solution variable away from the nodal values
Phi_x = Phi_node + Beta * Grad(Phi).(r_x - r_node)
where r is the position vector.
Beta = 0 means there the solution is nearly constant, and no need for the gradient contribution anyways.
Beta = 1 means full contribution of the gradient.
The details are more complex, but that should be enough to get the idea.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Opaque is offline   Reply With Quote
help with UDF for contact angle based on contact line velocity gandesk Fluent UDF and Scheme Programming 14 October 29, 2012 13:58
How to calculate Velocity? Kali Sanjay Phoenics 1 May 1, 2006 13:57
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 02:15
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
