December 3, 2019, 05:54 |
Domain Initialization
Michael Hopfinger
Rep Power: 9 |
is there a chance to initialize from a res-file that does not contain every domain of the def-file? In my case: I've got a steady-state solution for a basic turbomachinery stage. Next step: I want to add a second stage downstream of the same first stage and use my already available steady-state solution of the first stage for initialization purposes. At this point CFX complains that it can't find initial values for the second stage in the initialization file which are obviously missing. Thank you |
December 3, 2019, 06:25 |
Rep Power: 143 |
Have you tried using the interpolation command line tool to transfer it rather than an initial condition?
December 3, 2019, 07:26 |
Michael Hopfinger
Rep Power: 9 |
No, I haven't thought about it yet. I will give it a try. If something else comes into your mind, let me know :-) thanks
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
Out File does not show Imbalance in % | Mmaragann | CFX | 5 | January 20, 2017 10:20 |
Monte Carlo Simulation: H-Energy is not convergating & high Incident Radiation | volleyHC | CFX | 5 | April 3, 2016 05:41 |
2 different uniform field initialization in one domain | rvl565 | OpenFOAM Programming & Development | 1 | December 6, 2015 00:40 |
Vertical Axis Wind Turbine Rotating Domain Problems | TWaung | CFX | 4 | May 1, 2012 03:14 |
