March 15, 2006, 10:26 |
Naca airfoil with to much drag
Hi!
I try to calculate a flow around some Naca 4 digit airfoils. In my calculation the lift is nearly right, but the drag is much too high. I'm comparing the calculated values with the book "theory of wing sections". Can you give me a reason or advice? I use a wall as boundary condition for a profil and the calculations are done with the standard k-epsilon turbulence model. Thank you Andreas |
March 15, 2006, 10:41 |
Re: Naca airfoil with to much drag
The K-E is probably your problem. they are not ideally suited for these kind of flows. An SST model would prob give you better results.
March 15, 2006, 10:53 |
Hi!
I tried this too, because I had the same idea but the results are nearly equal. So I don't know what I'm doing wrong. Andreas |
March 15, 2006, 12:22 |
What advection scheme are you using ? Try specified Blend or High Res.
March 15, 2006, 12:43 |
what scheme you are using? because if you are trying for some supersonic / hypersonic case, then use upwind scheme. other thing is use local time scale factor<1.
March 15, 2006, 12:52 |
Check this forum, there are a lot of topics with this problem. You need very fine mesh, y+ bellow 2, run as transident, SST turbulence model with transition model, high resolution advection scheme.
March 17, 2006, 06:13 |
Hi!
Thanks for your help. It worked. Sorry, that I didn't search in the post. Andreas |
Lift and Drag Coefficient data for NACA 2412 Airfoil | mahbub03 | Main CFD Forum | 22 | May 25, 2014 15:39 |
Lift and drag coefficient with strange values for NACA airfoil | antonio_ing | OpenFOAM Running, Solving & CFD | 16 | September 13, 2012 12:21 |
Symmetric NACA Airfoil Lift and Drag Data | jrider22 | Main CFD Forum | 3 | April 15, 2010 04:59 |
NACA 23020 airfoil drag and lift calculation. | Zmur | CFX | 2 | December 23, 2008 16:35 |
Drag prediction for Naca 23012 airfoil | Ravel Bogatec | CFX | 17 | February 15, 2008 00:21 |
