the same case cannot run on a different computer
Hello, I copy the .def and the .bak file from HPC to my PC, but when I run it without any change(except directories), it shows error like this:
| ****** PROBLEM REPORT ****** | |--------------------------------------------------------------------| | Subsystem: Input and Output | | Subroutine name: ErrAction | | Severity level: Fatal Error | | Error message number: 001100279 | |--------------------------------------------------------------------| | Message: | | | | Unable to process the invalid physical name: AREA | | | | | | | | | | | +================================================= ===================+ +================================================= ===================+ | ****** PROBLEM REPORT ****** | |--------------------------------------------------------------------| | Subsystem: Input and Output | | Subroutine name: ErrAction | | Severity level: Fatal Error | | Error message number: 001100279 | |--------------------------------------------------------------------| | Message: | | | | Stopped in routine ReadPhysNames | | | | | | | | | | | +================================================= ===================+ +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | Error interpolating results onto the new mesh: C:\Program | | Files\ANSYS Inc\v180\CFX\bin\winnt-amd64\solver-mpi.exe exited | | with return code 1. | +--------------------------------------------------------------------+ can anyone help me? thanks in advance! |
When the case runs in HPC, every thing is fine
CFX error messages are not very helpful. You cannot say what is wrong from the error message alone, it has to be read in context.
My guess of what is happening here is that there is a problem during interpolation of the initial condition from a previous run. Also, have you got a mesh region called "AREA"? If so I would change this mesh region name to something which does not clash with built-in CFX variable names. |
This problem has been solved in a way....
The solver can read res file from each other in version 18.2~19.0 as initial file. The higher version can always open a file in a lower version, while it cannot be opened on the contrary. I can use HPC (version 18.2 ) and Super Computer(version 18.1 and version 19.0) for calculation and my PC (version 18.0) for post-processing. |
