Can you please confirm that I have set up the simulation conditions correctly? |
April 26, 2022, 04:04 |
Junyeol
Rep Power: 4 |
Thanks to all of you, I have made great progress in my work.
I need to get 2 values as a result. This simulation is run with a model with two inlets and two outlets. The first value is fraction at each inlet at one outlet and the second value is isolation from the entire model. The second was solved by calculating the residence time. With the help of the forums, I managed to get a reasonable results. However, I am not familiar with the additional value yet, so I want to verify that the settings I have made are correct. 1) recirculation 1. Set additional value 'recirculation'. Specific, Unit[], Scalar 2. Set Default Domain > Fluid Models>Additional value>recirculation(check) > Transport Equation 3. Set Inlet Domains > Boundary Details > Additional Variables> Value Inlet(A):1 Inlet(B):0 4. Set Expressions> ratio = massFlowAve(recirculation)@Inlet(A) 5. Set output control>Monitor>Monitor Points and Expressions>Option : Expression, Expression Value : Ratio 6.On the results, check Calculator As massflowAve, Outlet 2) isolation 1. Set additional value 'Isolation'. Volumetric, Unit[s], Scalar 2. Set Default Domain > Fluid Models>Additional value>Isolation(check) > Transport Equation 3. Set Sub Domains > Set location as all > Sources > Isolation > Option : Source, Source = 1 4. Set Inlet Domains > Boundary Details > Additional Variables> Value Inlet(A) : 0[s] Inlet(B) : 0[s] 5. On the results, check Contour as Isolation I think the result of 1) is the fraction at each inlet at the outlet. I think that the result of 2) is the residence time mapped to the set contour. I want to know if those values are the values I want. Dear all, thank you for your help as always. |
April 26, 2022, 05:32 |
Rep Power: 143 |
1) Isn't the value of ratio = massFlowAve(recirculation)@Inlet(A) = 1 because you defined it to be 1 in line 3?
You probably want ratio = massFlowAve(recirculation)@OUTLET to get the mixing ratio at the outlet of the two inlets.
April 26, 2022, 23:11 |
Junyeol
Rep Power: 4 |
What I gave the value to outlet(A) was written incorrectly as Inlet(A). Thanks for pointing it out.
April 26, 2022, 23:26 |
Rep Power: 143 |
I cannot see any issues with what you have written. But you cannot debug a simulation from that, you need to run it and see if it behaves as expected.
2D airfoil Simulation Kwsst boundary conditions | losiola | OpenFOAM Pre-Processing | 2 | August 11, 2018 08:54 |
Why opening boundary for multiphase simulation must set Volume Fraction of each phase | TerryNiu | CFX | 2 | March 13, 2018 06:49 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
Waterwheel shaped turbine inside a pipe simulation problem | mshahed91 | CFX | 3 | January 10, 2015 11:19 |
Help! How to set boundary conditions of this model??? | kylin1282869061 | Main CFD Forum | 8 | December 28, 2013 07:52 |
