how to DES solution?
Old   April 2, 2006, 08:38
Default how to DES solution?
prity
Hi to all, i am doing transient analysis of a pressure vessel type chambr.I am thinking from analysis that it may be case of highly seperated flow.so i want to use DES.i have not exp of using DES.so can anybody tell me how to use it?what are the requirements?what should be limit of courant no?I have read manual but it does not givr so much for that.ther are no tutorials regarding that.it says that ur mesh should be refined near wall region so DES can calulate seperated flow but how much?In my geometry it contains upto 5*1 m^2 lenth and width.i have used upto 7 lakh elements.How far i can go for DES?which parametrs should be cheked during run and after run?anyone's help would be highly appreciated. Thaks to all.
Old   April 2, 2006, 08:54
Default Re: how to DES solution?
Thien
Hi, you shoud refer to j.paper 'The inner-outer layer interface in large-eddy simulations with wall-layer models' by U. Piomelli et al., Int. J. Heat and Fluid Flow, 2003.
Old   April 3, 2006, 02:37
Joe
There is also a paper called 'young person's guide to DES' or something like that. If I remember correctly it is from Spalart, but I am not really sure. You should search for that paper. Concerning the Courant number: CFX is an implicit solver. Consequently the limit for your time step is the timescale of the smallest vorticies you want to resolve.
Most important in my opinion is to realize the differences in the philosophy of RANS and the philosophy of LES.
interFoam solution tolerances mgdenno OpenFOAM 4 September 13, 2011 12:58
Transient, initial variables from a previous solution nakor FloEFD, FloWorks & FloTHERM 0 April 22, 2011 04:34
Problem with DES model mehul Phoenics 0 April 12, 2006 08:00
Problem with DES model mehul Fidelity CFD 0 April 12, 2006 08:00
Discussion about Mesh independant solution Seb Main CFD Forum 13 May 22, 2001 13:37
