Is the flow 2D or 3D if I used periodic interface? |
February 13, 2020, 18:03 |
Andro
Rep Power: 6 |
If I used periodic interface in CFX, is the flow 2D or 3D? I know that if I used small thickness and symmetric boundary for the front and back face of the domain, the flow considered 2D. Please, can anyone help me to understand this point? Thanks In advance, A.M. |
February 13, 2020, 18:36 |
Rep Power: 143 |
Are you are asking what is the difference between a 2D model with symmetry planes on top and bottom Z faces (assuming the flow is in the XY plane), and replacing those symmetry planes with translational periodic boundaries?
If that is your question: The symmetry plane approach is closest to a true 2D simulation as no flow in the third dimension is possible. The periodic boundary approach allows flow in the third dimension, but that flow is the same at all Z values. The periodic approach is useful in axisymmetric flows with swirl as the third dimension can capture the swirl effect.
February 13, 2020, 18:48 |
Andro
Rep Power: 6 |
Yes, this is my question. If I want to make a heave mode for airfoil, which is 2D shape. What should I considered, periodic boundary or symmetry? Thanks.
February 14, 2020, 06:01 |
Rep Power: 143 |
Have a think about what my previous post said. You should be able to work it out from that. You need to understand these options for you to be able apply them.
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 01:13 |
How to use the CFX periodic interface | zhihuawan | CFX | 61 | January 15, 2018 16:20 |
[ICEM] periodic blocking - blade-to-blade turbine flow volume | Jonathan | ANSYS Meshing & Geometry | 7 | July 11, 2014 19:40 |
Periodic boundary conditions in 3D Eulerian granular flow simulations | dsm | FLUENT | 4 | March 2, 2012 19:04 |
Periodic BCs for flow through body centered cubic | Luigi_ | STAR-CCM+ | 1 | January 26, 2011 04:48 |
