April 19, 2006, 04:25 |
Opening
Hi cfx users,
I have a problem with a opnenig boundary condition. The only inlet/outlet of my domain is set as an opening condition. The flow is expected to be sucked in at some location of this boundary and flowing out at some others. I use the condition "Static Pres. (entrain) = 0" (I haven't notice any difference with the other conditions available). The flow is driven by some moving wall inside the domain. So, logically, I expect to have massflow = 0 at this boundary. And it is not!! The average velocity coming out at the opening is about 2-3% the velocity of the moving wall! This is physically impossible! Where can be the problem?? Can it be a mesh problem? I add also that I reach 10^-5/10^-6 for the rms residuals, so I don't think it's a convergence problem... Thanks for help, Andrew |
April 19, 2006, 13:37 |
Re: Opening
Measure the mass flow, not the velocity.
April 19, 2006, 15:28 |
Re: Opening
Yes, thatīs what I did. I have just converted the massflow into velocity to give a way to compare the difference...
Regards, Andrew |
April 19, 2006, 18:23 |
Re: Opening
Use the massflow function either as a monitor point during convergence or in CFX-Post to calculate massflow rate. Then it uses the exact values at the integration points and gives the true simulated massflow. Glenn Horrocks |
April 20, 2006, 14:00 |
Re: Opening
Post will also use the IP flows.
Andrew, what is the result of the mass flow calc? Make sure you use massFlowABS, otherwise all the flows will be positive and you'll get the total flow through the face, not the net flow. How did you compute the velocity from mass flow (i.e. what expression or equation did you use, as the details may introduce errors)? |
opening temperature for the opening BC | sujay | CFX | 5 | June 2, 2010 08:04 |
Opening Vs outlet BCs and temporary wall issue | Sam | CFX | 0 | January 16, 2008 18:59 |
Help setting up pressure function across opening | Jenny | CFX | 3 | October 18, 2007 00:16 |
Additional Variables- in the Opening BC. | Houman | CFX | 0 | October 2, 2006 08:09 |
Additional Variables at the Opening Boundary | Houman | CFX | 0 | August 22, 2006 12:27 |
