Error Restarting Transient Particle Tracking
I've been running a transient particle tracking simulation with fortran Particle User Routines for erosion calculations but have come across an error when trying to restart the simulation. I get the below error at the end of the 4th outer loop and it seems to be to do with the wall erosion routines not being transferred/located. Has anyone seen something similar before or know a workaround?
Parallel run: Received message from slave ----------------------------------------- Slave partition : 9 Slave routine : ErrAction Master location : PRB_MESSAGE Message label : 001100279 Message follows below - : +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | Message: | Unknown user routine ZN1 Parallel run: Received message from slave ----------------------------------------- Slave partition : 9 Slave routine : ErrAction Master location : PRB_MESSAGE Message label : 001100279 Message follows below - : +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | Message: | USER ROUTINE: I¦ ˜ could not be loaded. Please check the Lib- | rary Path, Library Name and Calling Name. For FORTRAN user routin- | es, the Calling Name should be in lower case. Parallel run: Received message from slave ----------------------------------------- Slave partition : 9 Slave routine : ErrAction Master location : PRB_MESSAGE Message label : 001100279 Message follows below - : +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | Message: | Stopped in routine PT_WALL_USER +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | The ANSYS CFX solver exited with return code 1. No results file | | has been created. +--------------------------------------------------------------------+ |
The solution was as simple as changing the name of the input file (.def) so it was different from the result (.res), classic!
