Force calcs by body section
Old   May 31, 2006, 13:18
Default Force calcs by body section
Roland
Hi
Im working with a car model. I want to calculate lift and drag forces by body component (i.e. wheel, hood, roof, etc) to determine effect on aerodynamic balance of body changes. Is there a mechanism withing Post that will allow me to define a subsection of my grid for this purpose?
It seems to me that, if I had to re-mesh, I could use virtual topology to combine areas of interest (i.e. combine the components that make up the tail section into a single virtual surface). But, the values I get when I tried this route are whacky (i.e hood lift is shown as 13,000 lbf) on a full scale model, even though the global values for body lift/drag are very close to wind tunnel data.
Any thoughts are greatly appreciated. Roland
Old   May 31, 2006, 13:59
Default Re: Force calcs by body section
Roland
Sorry to followup on my own post, but Im assuming my virtual topology numbers are actually correct- I did not include ambient pressure over that area, which would account for the crazy numbers. Duh!
Still, can someone let me know if there is a way to partition out areas of a results file for analysis of forces on subsections? Doing this as virtual topology is not always appropriate, since that is dependent on the CAD geometry/source which may not have surfaces segmented as I want to study them.
Best, Roland
Old   June 1, 2006, 17:06
Jason
Look into the interpolation tool which can be used to generate difference parameters between results files. The difference paramaters are then available in Post.
Old   June 1, 2006, 17:17
Default Force calcs, comparing results in Post
Roland
Jason
I had tried Interpolation between 2 results files- where the only difference between the simulations was the inlet velocity. Unfortunately, Interpolation does not seem to create a 'Difference Force' paramater, but it does create many others- i.e. 'Difference Pressure'. Because of this, any vector plot or function calculator involving Force always includes ambient pressure (1 atm). Since a 'Difference Force' parameter is not apparently calculated, Interpolation does not help in determining relative forces. I dont know why Interpolation does not seem to calculate delta for Force, but I cannot find a way around that. Any ideas? Or, maybe there is another approach?
Again, my goal is simply to determine the force (lift as a positive or negative component) by area on an automobile at various speeds, which was something easy to do in another CFD package I used with a previous employer.
Best, Roland
dsmcInitialise - dsmcFoam archymedes OpenFOAM Pre-Processing 94 July 15, 2016 16:14
Force can not converge colopolo CFX 13 October 4, 2011 22:03
Body force at the cell face Souviktor Fluent UDF and Scheme Programming 0 March 31, 2009 08:54
DPM Body Force Sandilya Garimella FLUENT 1 April 8, 2008 03:30
UDF for lift force on a bluff body sawa FLUENT 2 April 11, 2005 03:06
