How to apply negtive pressure to outlet
Old   May 31, 2006, 21:44
Default How to apply negtive pressure to outlet
bioman66
Hi. I want to use CFX to solve this kind of problem : Chamber (A) is link with chamber (B) by a long silicin tubing. Chamber(A) contains water inside with a top little hole to the atmosphere and Chamber(B) is empty. A negtive pressure is applied at a top little hole of chamber(B). I want to simulate the flow pattern when water is sucked from chamber(A) to chamber(B). I set the reference pressure to 1 atm and opening pressure to 0 pa at the hole of chamber(A) and opening pressure to -1.05 Mpa to the hole of chamber (B). After calculation, the results is not reasonable. Could anyone can tell me how to set the boundary conditions on these chambers?
Old   June 1, 2006, 03:17
Default Re: How to apply negtive pressure to outlet
Joe
How are you modelling the problem? Post your command file + pic of your geometry ...
How on earth is creating a -1 MPa vacuum suction physically viable in air?
Old   June 1, 2006, 09:44
garywang
Joe : The simple picture is shown as following
Open |----| |----| |----| |---| <----- suction here |___________| | | | | | | | A | | B | | | | |
| |____________| |
|________________| Because I set the reference pressure to 1 atm, I think the relative pressure at opening of A should be zero, and suction pressure at B should be negtive to cause outward direction and water can move from A to B. I hope you can tell me more , please. Is it correct? Or should I use absolute pressure ?
Old   June 1, 2006, 09:45
garywang
sorry ! this pic can not be shown corretly.
Old   June 1, 2006, 09:57
Joe
Post your command file + a proper pic of your geometry.
We need decent input information to offer advice, we arnt telepathic.
www.imagedump.com could be usefull for hosting your images ...
Old   June 3, 2006, 01:40
garywang
Dear Joe I have post my pic on the www.imagedump.com. The file name is container, user's name is bioman. The command file is shown as following: ------------------------------------------------------------ Installed patches:
* Service Pack 1 Setting up CFX-5 Solver run ... +--------------------------------------------------------------------+ | | | CFX Command Language for Run | | | +--------------------------------------------------------------------+ LIBRARY:
CEL:
EXPRESSIONS:
DenWater = 998 [kg m^-3]
levelini = 0.08 [m]
VFWater = step((levelini-y)/1[m])
PressIni = DenWater*g *VFWater*(levelini-y)
VFAir = 1-VFWater
END
END
MATERIAL: Air at 25 C
Material Description = Air at 25 C and 1 atm (dry)
Material Group = Air Data, Constant Property Gases
Option = Pure Substance
Thermodynamic State = Gas
PROPERTIES:
Option = General Material
Thermal Expansivity = 0.003356 [K^-1]
ABSORPTION COEFFICIENT:
Absorption Coefficient = 0.01 [m^-1]
Option = Value
END
DYNAMIC VISCOSITY:
Dynamic Viscosity = 1.831E-05 [kg m^-1 s^-1]
Option = Value
END
EQUATION OF STATE:
Density = 1.185 [kg m^-3]
Molar Mass = 28.96 [kg kmol^-1]
Option = Value
END
REFRACTIVE INDEX:
Option = Value
Refractive Index = 1.0 [m m^-1]
END
SCATTERING COEFFICIENT:
Option = Value
Scattering Coefficient = 0.0 [m^-1]
END
SPECIFIC HEAT CAPACITY:
Option = Value
Reference Pressure = 1 [atm]
Reference Specific Enthalpy = 0. [J/kg]
Reference Specific Entropy = 0. [J/kg/K]
Reference Temperature = 25 [C]
Specific Heat Capacity = 1.0044E+03 [J kg^-1 K^-1]
Specific Heat Type = Constant Pressure
END
THERMAL CONDUCTIVITY:
Option = Value
Thermal Conductivity = 2.61E-02 [W m^-1 K^-1]
END
END
END
MATERIAL: Water
Material Description = Water (liquid)
Material Group = Water Data, Constant Property Liquids
Thermodynamic State = Liquid
PROPERTIES:
Thermal Expansivity = 2.57E-04 [K^-1]
Absorption Coefficient = 1.0 [m^-1]
Option = Value
END
DYNAMIC VISCOSITY:
Dynamic Viscosity = 8.899E-4 [kg m^-1 s^-1]
Option = Value
END
EQUATION OF STATE:
Density = 997.0 [kg m^-3]
Molar Mass = 18.02 [kg kmol^-1]
Option = Value
END
REFRACTIVE INDEX:
Option = Value
END
Option = Value
END
Option = Value
Reference Specific Enthalpy = 0.0 [J/kg]
Reference Specific Entropy = 0.0 [J/kg/K]
Specific Heat Capacity = 4181.7 [J kg^-1 K^-1]
END
Option = Value
Thermal Conductivity = 0.6069 [W m^-1 K^-1]
END
END
END END EXECUTION CONTROL:
PARALLEL HOST LIBRARY:
HOST DEFINITION: garywang
Installation Root = C:\Program Files\Ansys Inc\CFX\CFX-%v
Host Architecture String = intel_p4.sse2_winnt5.1
END
END
PARTITIONER STEP CONTROL:
Multidomain Option = Independent Partitioning
Runtime Priority = Standard
MEMORY CONTROL:
Memory Allocation Factor = 1.0
END
PARTITIONING TYPE:
MeTiS Type = k-way
Option = MeTiS
Partition Size Rule = Automatic
END
END
RUN DEFINITION:
Definition File = D:/icem_dir/tidecellbag/test3.def
Interpolate Initial Values = Off
Run Mode = Full
END
SOLVER STEP CONTROL:
EXECUTABLE SELECTION:
Double Precision = Off
END
MEMORY CONTROL:
END
PARALLEL ENVIRONMENT:
Number of Processes = 1
Start Method = Serial
END
END END FLOW:
DOMAIN: fluid
Coord Frame = Coord 0
Domain Type = Fluid
Fluids List = Air at 25 C,Water
Location = Assembly
BOUNDARY: fluid Default
Boundary Type = WALL
Location = WALL1 1,WALL1 10,WALL1 11,WALL1 12,WALL1 13,WALL1 14,WALL1 \
15,WALL1 16,WALL1 17,WALL1 18,WALL1 19,WALL1 2,WALL1 20,WALL1 \
21,WALL1 22,WALL1 23,WALL1 24,WALL1 25,WALL1 26,WALL1 3,WALL1 \
4,WALL1 5,WALL1 6,WALL1 7,WALL1 8,WALL1 9,WALL2 1,WALL2 10,WALL2 \
11,WALL2 12,WALL2 13,WALL2 14,WALL2 15,WALL2 2,WALL2 3,WALL2 4,WALL2 \
5,WALL2 6,WALL2 7,WALL2 8,WALL2 9
BOUNDARY CONDITIONS:
WALL INFLUENCE ON FLOW:
Option = No Slip
END
END
END
BOUNDARY: inlet
Boundary Type = OPENING
Location = IN
FLOW DIRECTION:
Option = Normal to Boundary Condition
END
FLOW REGIME:
Option = Subsonic
END
MASS AND MOMENTUM:
Option = Opening Pressure and Direction
Relative Pressure = 0 [atm]
END
END
FLUID: Air at 25 C
VOLUME FRACTION:
Option = Value
Volume Fraction = 1
END
END
END
FLUID: Water
VOLUME FRACTION:
Option = Value
Volume Fraction = 0
END
END
END
END
BOUNDARY: outlet
Location = OUT
FLOW DIRECTION:
END
FLOW REGIME:
Option = Subsonic
END
MASS AND MOMENTUM:
Relative Pressure = -1000 [Pa]
END
END
FLUID: Air at 25 C
VOLUME FRACTION:
Option = Value
Volume Fraction = 1
END
END
END
FLUID: Water
VOLUME FRACTION:
Option = Value
Volume Fraction = 0
END
END
END
END
DOMAIN MODELS:
BUOYANCY MODEL:
Buoyancy Reference Density = 1.185 [kg m^-3]
Gravity X Component = 0 [m s^-2]
Gravity Y Component = -9.8 [m s^-2]
Gravity Z Component = 0 [m s^-2]
Option = Buoyant
BUOYANCY REFERENCE LOCATION:
Option = Automatic
END
END
DOMAIN MOTION:
Option = Stationary
END
MESH DEFORMATION:
Option = None
END
REFERENCE PRESSURE:
END
END
FLUID: Air at 25 C
FLUID MODELS:
FLUID BUOYANCY MODEL:
Option = Density Difference
END
MORPHOLOGY:
Option = Continuous Fluid
END
END
END
FLUID: Water
FLUID MODELS:
END
MORPHOLOGY:
END
END
END
FLUID MODELS:
COMBUSTION MODEL:
Option = None
END
HEAT TRANSFER MODEL:
Homogeneous Model = Off
Option = None
END
THERMAL RADIATION MODEL:
Option = None
END
TURBULENCE MODEL:
Option = Laminar
END
END
FLUID PAIR: Air at 25 C | Water
INTERPHASE TRANSFER MODEL:
Interface Length Scale = 1. [mm]
Option = Mixture Model
END
MASS TRANSFER:
Option = None
END
SURFACE TENSION MODEL:
Option = None
END
END
INITIALISATION:
Option = Automatic
FLUID: Air at 25 C
INITIAL CONDITIONS:
VOLUME FRACTION:
Option = Automatic with Value
Volume Fraction = VFAir
END
END
END
FLUID: Water
INITIAL CONDITIONS:
VOLUME FRACTION:
Volume Fraction = VFWater
END
END
END
INITIAL CONDITIONS:
Velocity Type = Cartesian
CARTESIAN VELOCITY COMPONENTS:
U = 0 [m s^-1]
V = 0 [m s^-1]
W = 0 [m s^-1]
END
STATIC PRESSURE:
Relative Pressure = PressIni
END
END
END
MULTIPHASE MODELS:
Homogeneous Model = On
FREE SURFACE MODEL:
Option = Standard
END
END
END
OUTPUT CONTROL:
RESULTS:
File Compression Level = Default
Option = Standard
END
TRANSIENT RESULTS: Transient Results 1
Include Mesh = No
Option = Selected Variables
Output Variables List = Absolute Pressure,Pressure,Total \
Pressure,Water.Velocity,Water.Volume Fraction
Time Interval = 0.02 [s]
END
END
SIMULATION TYPE:
Option = Transient
INITIAL TIME:
Time = 0 [s]
END
TIME DURATION:
Option = Total Time
Total Time = 10 [s]
END
TIME STEPS:
Option = Timesteps
Timesteps = 0.02 [s]
END
END
SOLUTION UNITS:
Angle Units = [rad]
Length Units = [m]
Mass Units = [kg]
Solid Angle Units = [sr]
Temperature Units = [K]
Time Units = [s]
END
SOLVER CONTROL:
ADVECTION SCHEME:
Option = High Resolution
END
CONVERGENCE CONTROL:
Maximum Number of Coefficient Loops = 2
Timescale Control = Coefficient Loops
END
CONVERGENCE CRITERIA:
Residual Target = 1.E-4
Residual Type = RMS
END
TRANSIENT SCHEME:
Option = Second Order Backward Euler
END
END END COMMAND FILE:
Version = 10.0
Results Version = 10.0 END +--------------------------------------------------------------------+ | | | Solver | | | +--------------------------------------------------------------------+
+--------------------------------------------------------------------+ | | | ANSYS CFX Solver 10.0 | | | | Version 2005.10.25-23.10 Tue Oct 25 23:48:51 GMTDT 2005 | | | | Executable Attributes | | | | single-32bit-optimised-supfort-noprof-nospag-lcomp | | | | Copyright 1996-2005 ANSYS Europe Ltd. | +--------------------------------------------------------------------+
+--------------------------------------------------------------------+ | Job Information | +--------------------------------------------------------------------+
Run mode: serial run
Host computer: GARYWANG Job started: Sat Jun 3 13:25:36 2006 +--------------------------------------------------------------------+ | Memory Allocated for Run (Actual usage may be less) | +--------------------------------------------------------------------+ Data Type Kwords Words/Node Words/Elem Kbytes Bytes/Node
Real 9818.0 455.89 536.33 38351.7 1823.56 Integer 1907.2 88.56 104.18 7450.0 354.24 Character 2433.1 112.98 132.91 2376.0 112.98 Logical 40.0 1.86 2.19 156.2 7.43 Double 227.7 10.57 12.44 1778.7 84.57 +--------------------------------------------------------------------+ | Total Number of Nodes, Elements, and Faces | +--------------------------------------------------------------------+ Domain Name : fluid
Total Number of Nodes = 21536
Total Number of Elements = 18306
Total Number of Hexahedrons = 18306
Total Number of Faces = 6158 +--------------------------------------------------------------------+ | Buoyancy Reference Information | +--------------------------------------------------------------------+ Domain Group: fluid
Buoyancy has been activated. The absolute pressure will include
hydrostatic pressure contribution, using the following reference
coordinates: ( 1.90000E-01, 4.10577E-01,-5.44734E-02). +--------------------------------------------------------------------+ | Average Scale Information | +--------------------------------------------------------------------+ Domain Name : fluid
Global Length = 1.1916E-01
Minimum Extent = 1.0000E-01
Maximum Extent = 4.1058E-01
Air at 25 C.Density = 1.1850E+00
Air at 25 C.Dynamic Viscosity = 1.8310E-05
Air at 25 C.Velocity = 0.0000E+00
Air at 25 C.Mass (Conservative) = 9.8683E-04
Air at 25 C.Mass (Normalised) = 9.8683E-04
Air at 25 C.Volume = 8.3277E-04
Air at 25 C.Volume Fraction = 4.9222E-01
Water.Density = 9.9700E+02
Water.Dynamic Viscosity = 8.8990E-04
Water.Velocity = 0.0000E+00
Water.Mass (Conservative) = 8.5653E-01
Water.Mass (Normalised) = 8.5653E-01
Water.Volume = 8.5911E-04
Water.Volume Fraction = 5.0778E-01
Water.Wave Speed = 1.0806E+00
Water.Froude Number = 0.0000E+00 +--------------------------------------------------------------------+ | Writing Selected transient file Transient Results 1: 0.trn | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | Checking for Isolated Fluid Regions | +--------------------------------------------------------------------+ No isolated fluid regions were found. +--------------------------------------------------------------------+ | The Equations Solved in This Calculation | +--------------------------------------------------------------------+ Subsystem : Momentum and Mass
U-Mom-Bulk
V-Mom-Bulk
W-Mom-Bulk
P-Vol
Subsystem : Volume Fractions
Mass-Water
CFD Solver started: Sat Jun 3 13:25:41 2006
UDF to adjust pressure outlet a.lynchy FLUENT 4 February 15, 2021 00:50
simple model, difficult outlet Eric CFX 7 May 23, 2014 08:13
Help ASAP! pressure inlet & outlet engahmed FLUENT 0 June 13, 2010 15:33
Pressure Rise Error emueller CFX 0 May 5, 2009 11:08
which b.c. i should apply for this prob.urgent raivish Siemens 2 January 11, 2006 03:00
