Simulating erosion on pelton buckets by silt laden flow |
May 11, 2020, 03:06 |
zehab
Rep Power: 12 |
Simulating the erosion by virtue of sediment particles laden in silt water on the buckets of Pelton turbine in a steady state using Frozen rotor.
Performed the multiphase analysis (air+water) both as the continuous phase (Eullarian) with solid particle (particle tracking ). When I do so the warning message pops out as "In Analysis 'Flow Analysis 1' - Domain 'Stationary': Particle tracking simulations with more than one continuous Eulerian phase are not supported". Came across a document released by ANSYS 2016 (document attached) to tackle such warning. The method defined in that document is about changing expert parameters. I am not able to find the expert parameter "pt multiphase = t" and expert parameter "pt multiphase min volfrc = 0.5" mentioned in the document attached. In addition to this I am a bit confused in choosing the following options 1. What reference density should I use? a.) Air b.) water |
cfx, fluid flow, particle transport |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
[rhoCentralFoam] simulating compressible inviscid flow | Yuval | OpenFOAM Running, Solving & CFD | 2 | January 27, 2016 21:33 |
simulating flow | pyxbird | FLOW-3D | 7 | October 24, 2012 11:30 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 21:31 |
Flow visualization vs. Calculated flow patterns | Francisco Saldarriaga | Main CFD Forum | 1 | August 2, 1999 23:18 |
