Shear strain rate insertion at Bingham plastic model |
May 12, 2020, 10:36 |
Ahammed Rubel
Dear Experts,
I want to simulate magneto-rheological fluid damper. Here I want to use default Bingham Plastic model at CFX. I have calculated Shear Stress for different current density by using APDL Electromagnetic . Shear Stress average value [(Bmax+Bmin)/2] =3186.55 T. Should I put this value as yield stress? For a specific shear stress how can I calculate Shear Strain Rate maximum and minimum value. For Bingham Plastic model which data need to insert? |
May 12, 2020, 12:44 |
Rep Power: 32 |
A Bingham fluid is defined by its Yield Stress and Viscosity Consistency (see ANSYS CFX documentation for details).
I understand a magneto-rheological fluid as fluid where its properties can be a function of magnetic field variables, say B or H. I would translate that as Yield Stress = Function F (B or H, Temperature, etc) Viscosity Consistency = Function G (B, or H, Temperature, etc) The shear strain rate limits are to control the numerics of how the viscosity is treated in the equations, they are not a physical property of the material. What are the F and G above? You should look for that information in the literature for that material.
[openSmoke] libOpenSMOKE | Tobi | OpenFOAM Community Contributions | 562 | January 25, 2023 09:21 |
Modeling viscosity. Shear strain=Shear rate? | jpina | FLUENT | 3 | January 28, 2022 05:37 |
How to define strain rate and shear rate magnitude in CFD-Post? | khhan0543 | Fluent UDF and Scheme Programming | 3 | January 13, 2017 14:38 |
Strain rate calculation for explicitly filtered constant smagorinsky model | cfdmms | Main CFD Forum | 2 | December 2, 2013 14:09 |
Flow of Bingham plastic model in Fluent 6.3 | koti121 | FLUENT | 0 | April 24, 2009 03:35 |
