Particle Tracking
Old   June 16, 2006, 08:28
Default Particle Tracking
Reena
I'm doing particle tracking. I have two different inlets. Inlet 1 = Ideal Air Inlet 2 = Veg Oil (particles)
When defining the inlet properties for inlet2 in CFX-Pre in the second tab it asks me for either mass flow/total P/etc...and I define mass flow rate. However when you move to the third tab (Fluid Values) to definie particle behaviour you have to define mass flow rate again.
My question is, the first mass flow rate I define, is it the combined flow rate of the veg. oil particles + air (being using to atomize it) and is the second mass flow that of the particles alone?
Thank you
Old   June 16, 2006, 10:08
Default Re: Particle Tracking
Neser25
Hi, As fare as i know, the 1st one is for air. Therefore, if you spray oil and air (together from inlet 2) you may define it. If you spray oil only (from inlet 2) then you should define it by zero (I recommend if you selecte velocity =0 not mass flow rate)
regards
Blood Damage Modelling via Particle Tracking in a Centrifugal Heart Pump scatman CFX 7 January 8, 2018 00:59
massless particle tracking problem Renold FLUENT 0 January 26, 2011 14:23
Particle Tracking for ion Jun CFX 2 August 31, 2010 08:19
Number density tracking rather than particle tracking Rebecca Main CFD Forum 2 April 23, 2009 12:52
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 01:29
