[Sponsors] | |||||
Heat transfer porous domain - between solid part and sourounding fluid |
Rep Power: 0 ![]() |
I am working on a heat transfer problem, which contains of solid, fluids and a porous domain. The porous domain consist of fluid and solid. At the interface between porous and fluid domain I defined for the solid part a heat transfer via heat transfer coefficient and outer temperature, but during the solver run I see a T-Energy Domain Interface Flow = 0 [W]. But if I look at the Solid.Heat Flux in CFX Post I see a significant value of heat flux, also if I integrate over the interface area. Where can I see the amount of heat flux from the solid of the porous domain to the surrounding fluid domain during the solver run? Is the T-Energy Domain Interface Flow only relevant if there is a porous-solid interface? Thanks a lot |
| Thread Tools | Search this Thread |
| Display Modes | |
