RSH does't connect for two WIN XP nodes
Old   June 15, 2006, 11:19
Default RSH does't connect for two WIN XP nodes
Ali
When I use rsh to check the connection between two nodes, it refusses connection with the following message
:Connection timed out rsh: can't establish connection
rsh is installed on both machines (master and slave).
I can ping the other computer, which means there is a network connection. Do I need any setup for Windows FireWall? Do you know a solution?
Ali
Old   June 15, 2006, 11:26
Default Re: RSH does't connect for two WIN XP nodes
opaque
dear Ali,
Did you go over the ANSYS CFX Producs Installation and Configuration Guide? There is a section for testing, modify and/or installing the rsh service on windows.
Also, you can contact your local support office.
Opaque
Old   June 15, 2006, 21:36
dhw34
We have been having the same problem, we can't find anything that has changed (since it had previously worked). We can rsh the slave to master and master to slave, but not slave to slave or master to master. Not sure of this is any help, but if we find out anything we can let you know.
Old   June 17, 2006, 12:59
Roland
Ali
Do try disabling the software firewall on both machines (master and slave) to eliminate that from the equation. If that doesnt permit connection to the remote RSH service, it may be authentication (implicit login, where you need to be logged in as the user account that is assigned to the remote RSH service (i.e. same user account on all machines, with appropriate permissions).
Roland
Old   June 17, 2006, 14:25
Ali
Thanks Roland..
Diasabling fire work makes it works. I think that inside setup of WIN xp SP2
Thanks.. Ali
Rocks 5.4 Rsh Connection Refused for Fluent 6.3 bucnikf90 Hardware 2 March 29, 2012 16:24
running without rsh between nodes hattonps OpenFOAM 10 March 22, 2010 15:02
connect failed with errno%3d113 wedsall OpenFOAM Running, Solving & CFD 2 November 3, 2008 04:17
meshing F1 front wing Steve FLUENT 0 April 17, 2003 12:37
