May 19, 2020, 15:14 |
Multiphase simulation heat pipe
Sai
Rep Power: 5 |
This is sai I am doing a project on heat pipe working fluid is water and it’s simulation in Ansys fluent I have choose VOF model and then regarding the boundary conditions I have doubt. I was supposed to do experiment using **watt as input to it and then calculating the temperatures at some points but by using simulation can I do it ? What all boundary conditions need to be given is heat flux to be given as boundary condition?Then after that I have problem with volume fractions I want to find volume fraction contours of both steam and water.Can some one please help me with this If any one has done project on this reply to this.Thanks IN advance.Please!🙏 |
May 19, 2020, 15:23 |
Gert-Jan
Rep Power: 27 |
This is the CFX-forum. You'd better consult the fluent-forum.
May 19, 2020, 15:46 |
Sai
Rep Power: 5 |
Heat pipe simulation | bensonnggl | CFX | 17 | September 3, 2017 20:42 |
simulation heat pipe | es99 | Fluent Multiphase | 0 | August 23, 2013 11:22 |
heat pipe simulation | teejey | FLUENT | 0 | August 20, 2013 07:27 |
FEA Simulation of heat pipe | bensonnggl | ANSYS | 0 | September 25, 2010 00:59 |
the simulation of the heat pipe | Crystal | FLUENT | 0 | June 21, 2008 10:38 |
