ICEM 10.0.1 inverted elements
Old   June 19, 2006, 13:50
Default ICEM 10.0.1 inverted elements
Fred
I've got a simple pipe geometry. Everytime I'm creating an ogrid i got negative volumes/elements on the inlet and outlet surfaces. the pre-mesh looks perfect but the pre-mesh quality check show me these elements, also i cant see them normally. What am I doing wrong. The geometry surface normals show all outside the domain. Please help me, its urgent.
Old   June 19, 2006, 16:03
Default Re: ICEM 10.0.1 inverted elements
Joe
Run the mesh checker/fixer.
Old   June 20, 2006, 02:33
Fred
I did. No change.
Old   June 20, 2006, 05:43
deLuther
Post picture of your geometry/topology and resulted mesh
Old   June 20, 2006, 07:32
myron
It almost sounds like you have pancaked blocks at the ends of the pipe. When you do the O-grid make sure you add the faces at the pipe ends so the O-grid passes through the ends.
If you turn on the Blocks make sure you don't have 0-thickness blocks at the ends of the pipe. If it turns out that you do - you can delete them.
Old   June 20, 2006, 08:22
Fred
Thank you myron. I found those pancaked blocks. Now the mesh is as fine as it looks like.
inverted elements in gambit ak FLUENT 0 September 27, 2007 00:53
ICEM and CFX report different number of elements Chris Basciano CFX 0 July 20, 2007 17:24
skewed, inverted elements exp FLUENT 0 June 15, 2007 11:56
ICEM TETRA - elongated elements Zbynek Main CFD Forum 1 June 28, 2004 16:08
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
