May 30, 2020, 10:10 |
Problem in exporting data
Rep Power: 8 |
Hi all,
I am trying to export the pressure data on a blade at specific points (100 points). So I create a polyline in cfx-post, which read the points from a file and export the pressure on that polyline. But the problem is that the pressure is written on just 99 points, not all the 100 points. All of the points are on the blade surface. What is the problem and how can I solve it? |
May 31, 2020, 06:46 |
Rep Power: 143 |
Use a point cloud, not a polyline to define your points.
May 31, 2020, 07:13 |
Rep Power: 8 |
Dear Glenn,
I’d tried to use point cloud instead of a polyline, but as I understood, the point cloud determines the points by itself. I mean that I want the pressure to be written at specific points with specific x, y and z. but the point cloud determines the points, for example, randomly or in equal space or other ways. So, I decided to use a polyline in which I could determine the points by myself. |
May 31, 2020, 18:54 |
Rep Power: 143 |
Have you looked at the point cloud option? There is a method: "From file" option, which appears to be where you import a CSV file with all the locations for the point. This appears to do exactly what you want.
June 1, 2020, 00:22 |
Rep Power: 8 |
Dear Glenn,
Of course I checked the options, but I cannot find “from file” option. Can you help me where is it? I attached the details window of the point cloud. That’s all I can see. |
June 1, 2020, 00:28 |
Rep Power: 143 |
You must be using an old version of CFX as the option does not appear to be there. About time to update I think.
June 1, 2020, 01:04 |
Rep Power: 8 |
I’m using ANSYS 2019 R1… anyway… it’s not possible for me to update it now.
June 1, 2020, 07:48 |
Rep Power: 8 |
try User Surface -> From File
June 16, 2020, 09:05 |
#9 |
Sumanth
Rep Power: 7 |
I encountered something similar recently. Even when you create a point cloud in CFD Post and you give in 100 as number of points, only 99 will be created.
I simply would give in 1 value extra to make up for this. Have no clue how and why the software does this. I usually take out data from a large number of points along the surface or line needed and then interpolate them onto the points I need later in Matlab. Ofc, this brings in an interpolation error but if you have enough number of data points, this error could be something which you can ignore. Hope this helps! |
June 16, 2020, 09:43 |
#10 |
Rep Power: 32 |
May I ask how you know there are 99 and not 100?
Are you looking at the column with the node number? or counted the lines one by one? CFD-Post numbers the rows in the .csv file starting at 0, even if you do not include the row number. Perhaps that is the problem?
June 18, 2020, 04:20 |
#11 |
Sumanth
Rep Power: 7 |
I stand corrected. Opaque was right
Moving boundary problem based on calculated data | sandro.grm | OpenFOAM Programming & Development | 52 | October 28, 2023 13:10 |
Exporting Particle Data | prX411 | CFX | 4 | April 3, 2018 12:00 |
problem during export of particle tracking data (good decription of the problem) | archetype | CFX | 0 | August 1, 2017 11:23 |
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) | cfdonline2mohsen | OpenFOAM | 3 | October 21, 2013 09:28 |
Problem in Track Data | selen | Siemens | 2 | August 7, 2003 13:06 |
