Sam
Rep Power: 3 ![]() |
I am new with CFX and I need your feedback in the following error;
| ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | USER ROUTINE: User Routine 1 could not be loaded. Please check th- | | e Library Path, Library Name and Calling Name. For FORTRAN user r- | | outines, the Calling Name should be in lower case I created my own code in Fortran and then compiled it. Then I created a new user routine? Do I have to recall the parameters again in the CEL? Please advise me. |
Rep Power: 25 ![]() |
Could you explain how you compiled it?
Sam
Thanks for the message. I used Microsoft Visual Studio and Intel Fortran Compiler Composer XE 2013. Then I called all New environment variables. in the end, Setup CFX to use Fortran routines.
The complied was working. |
I understand which compiler you used, but apologies for asking again:
which CFX command did you use to compile the user routine? There is a specific way to compile a CFX library to be located in the correct folder for the specific precision, compiler, etc Did you compile from CFX-Pre? or the command line?
Sam
Yes. I use the command line window from CFX-Pre?
Tool------> Command line |
If you take a look at the library path in the subroutine definition, let us call it simulation_library_path.
If you browse the folder where your simulation is defined, i.e. where your definition file is written. Is it the same as the simulation_library_path above? If it is, can you see a folder named winnt-amd64? If yes, is there a file with the library name you used in the simulation setup in any of the sub-folders? Summary: you must verify the library has been created where the simulation expects it.
Sam
Thanks for the text. Yes, I can see winnt-amd64 folder and it has two files.
Please advise in the following error: | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | Unable to load symbol motion from C:\fortran\winnt-amd64\motion.d- | | ll: The specified procedure could not be found. best |
Display Modes | |
Calculation Error in USER subroutine | Asif17 | CFX | 3 | June 29, 2016 04:45 |
Error in subroutine CONVERT_NAME_U2S_INT | JDQFD | CFX | 2 | January 21, 2014 10:19 |
Fortran Subroutine Error | sergiorbrett | CFX | 12 | September 3, 2012 08:40 |
Errorin subroutine appeared when applying cavitation model | pitisrisuk | CFX | 1 | July 2, 2012 04:36 |
FIDAP subroutine: USRBDY | Shuwen Tzeng | FLUENT | 0 | September 3, 2004 04:40 |
