July 2, 2020, 15:53 |
Turbomachinery Domain Interfacing
Evan
Rep Power: 5 |
I'm relatively new to CFD (I've been working with ANSYS for six months) and I'm working on a new project to model a propeller. I have three domains: two stationary for pipe inlet and pipe outlet and a rotating domain for the propeller. I keep running into an issue where my domain interfaces do not merge smoothly (from pipe inlet into the propeller and exiting at the pipe outlet). Would anyone who has a few more years experience be able to help a newcomer out to smoothly interface a stationary domain to a rotating domain? |
July 2, 2020, 19:08 |
Rep Power: 143 |
What do you mean by "do not merge smoothly"? Please show what you mean on an image.
July 3, 2020, 03:25 |
Gert-Jan
Rep Power: 27 |
Indeed we don't know what varaibles you are showing, so it is difficult to give advice. But can't it be that you are looking ar Velocity and Total Pressure? If so, then look at Velocity and Total Pressure in Stationary Frame.
July 6, 2020, 08:03 |
Apology for ambiguity
Evan
Rep Power: 5 |
Apology for the ambiguity; let me rephrase the question: What is the most appropriate method to connect a stationary reference frame and a rotating reference frame? The pictures above shown is a pressure contour and a velocity streamline plot. There are three domains, two stationary reference frames (acting as pipe inlets and outlet) and the rotating reference frame in the middle. The pressure contour and velocity streamline do not have a smooth connectivity from one reference frame to another and was questioning how to appropriately connect a moving and stationary reference frame.
July 6, 2020, 08:49 |
Gert-Jan
Rep Power: 27 |
As mentioned: you are looking at Velocity and Total Pressure. You should look at Velocity and Total Pressure in Stationary Frame.
July 15, 2020, 12:26 |
Henrique Stel
Rep Power: 17 |
It is not clear what you mean by "smooth connectivity". If you mean the behavior of the streamlines and pressure contours, please have in mind that when transitioning from stationary to rotating domains CFD Post will assume by default that the Velocity from which it will calculate the streamlines assume the local frame of reference, which means that in the rotating frame it will "redraw" the streamlines orientation to the velocity in a rotating frame of reference. If you want to see a smooth transition in this sense, plot the streamlines using "Velocity in Stn Frame" as suggested above. Also, it is not clear in the image if the rotating domain was assumed as a 360 or only one passage. If you connect a 360 domain with a single-passage rotating domain CFX will employ pitch scale, which may cause some streamlines and contours to look disconnected since CFX will have to interpolate data across the interface.
ansys cfx, pump, turbomachinery |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
Domain size influence in unbounded domains model | Reoyo | Main CFD Forum | 10 | May 4, 2018 08:30 |
Periodic Pressure drop | cfd_begin | CFX | 10 | May 25, 2017 07:09 |
Out File does not show Imbalance in % | Mmaragann | CFX | 5 | January 20, 2017 10:20 |
Pressure distribution on a wall | darazsbence | CFX | 17 | October 6, 2015 10:38 |
