Difference between pressure & abs pressure in POST |
June 27, 2006, 20:24 |
Hi All,
I'm very new to CFX I want to draw pressure at certain plane. I created a variable called Pabsolute which equals pressure plus reference pressure (as I understand from CFX manual). I want to know the difference in CFX-Post between (Pressure + Reference pressure) and existing Absolute Pressure variable. It shows different minimum values and shares same maximum value!! Thank you |
June 27, 2006, 20:32 |
Re: Difference between pressure & abs pressure in
Absolute Pressure is equal to Pressure + Relative Pressure. The difference in your range may be because of hybrid values. CFX has two values stored at nodes, the "Conservative" value corresponds to the control volume, whereas the hybrid value is the boundary condition value. At a wall, pressure is the same whether it is hybrid or conservative, but at inlets and outlets it could be different.
Regards, Robin |
Display Modes | |
UDF to define or adjust pressure??? | engahmed | FLUENT | 0 | July 6, 2010 18:19 |
Gas pressure question | Dan Moskal | Main CFD Forum | 0 | October 24, 2002 23:02 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 06:13 |
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) | HB &DS | CFX | 0 | January 9, 2000 14:19 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 16:00 |
