Cfx simulation of radial turbine stator
Old   July 3, 2020, 14:35
Default Cfx simulation of radial turbine stator
Pablo Tapia
Pablotf12 is on a distinguished road
Good afternoon guys.
I am trying to simulate a stator for an organic Rankine cycle radial turbine, First I created the geometry using Solidworks and export it to Ansys workbench, I mesh the domain, define boundaries and all required specifications. However, when I run the simulation, the Mach number has an order of magnitude of 10^2, which is odd as results obtained considering only one of the stator nozzles are right (Mach number at the outlet of about 2). The simulation is 2D and as inlet and outlet boundary conditions I set the total relative pressure and static relative pressure respectively
I have been thinking and must be related to the simulation setup.
Kind Regards.
Pablo
Pablotf12 is offline   Reply With Quote
Old   July 4, 2020, 06:33
ghorrocks is a jewel in the roughghorrocks is a jewel in the roughghorrocks is a jewel in the roughghorrocks is a jewel in the rough
If the maximum Mach number increases to unrealistic values your simulation is starting to diverge. You don't have a floating point error yet, but you soon will. This FAQ might help: https://www.cfd-online.com/Wiki/Ansy...do_about_it.3F
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   July 13, 2020, 05:17
Pablo Tapia
Thanks, I managed to find the solution to my problem, Kind Regards
Pablo
CFX Simulation of tidal turbine rotor mujahidbadshah CFX 12 January 19, 2017 17:46
CFD analysis on wind turbine rotor Ken (Wind Turbine CFD Super Rookie) Main CFD Forum 45 February 9, 2016 14:07
initial condition in transient turbine simulation CFDturbomachinery CFX 5 November 5, 2014 06:28
ANSYS CFX simulation: Post CFX error MInXD CFX 3 May 19, 2013 19:24
Problem with torque output from a turbine simulation. pa-dundas FLUENT 3 August 30, 2011 12:25
