friction & windage
Old   August 11, 2006, 03:48
Default friction & windage
alex
hi, I am modelling a rotating machinery by using the MFR CFX option. I have to compute the friction and windage of this machine. The rotation axis is z. To determine the friction and windage ( ie torque * rotating velocity), i have to find, in the CFX post, the torque_z()@"rotating part". Rotating wall's torque are negative value. if i compute the static wall's torque, some value are >0 and some other value are <0. It's very strange!! How can i find the friction and windage by using CFX post? I don't know if i have to consider the torque on stator. I don t understand the positive torque on some stator's wall?
best regards
Alex
Old   August 14, 2006, 06:21
Default Re: friction & windage
Turbine
Alex
Did you have a look at the rotation direction? Is this the cause for +ve and -ve torgues ?
GT
Old   August 16, 2006, 03:00
Default friction & windage - how to determine it with post
alex
i understand that torques could be positive or negative values for the rotor (sign depends on the rotation direction). But, for the stator, some value are positive and some others, are negative. That is very strange. Also, i don't know how can i evaluate the friction and windage using cfx post.
caculation of friction factor Dilip Main CFD Forum 9 February 23, 2016 05:00
Skin friction in fluent is wrong syler3321 FLUENT 2 March 24, 2011 08:05
Openfoam friction coefficient differences. Peter88 OpenFOAM Post-Processing 0 February 8, 2011 10:07
friction & windage losses prediction - help needed alex CFX 0 August 28, 2006 09:51
Compute Skin friction coef by hand Francois FLUENT 1 February 10, 2006 06:21
