Contact Connection in Mesh?
Old   September 1, 2020, 09:11
Default Contact Connection in Mesh?
Sanjay
skdubey is on a distinguished road
What if the Contact Connection in the Mesh is suppressed and it been solved using the physics. For meshing of two different bodies which one is better Group or Merge? I would like to have conformal meshing around the multi bodies.
skdubey is offline   Reply With Quote
Old   September 1, 2020, 15:28
karachun's Avatar
karachun is on a distinguished road
Why not try it by yourself and see what will happen? I think that no one will make a test model and do these steps for you.
If bodies are in the same part then Ansys Meshing will try to create conformal mesh but this may be challenging, sometimes.
karachun is offline   Reply With Quote
Old   September 2, 2020, 13:57
Default Failed Mesh Due to Non Conformal or Duplicate or Degenerate Mesh Element
Sanjay
The mesh translation to Fluent failed due to non-conformal, duplicate, or degenerate mesh elements.
A. I tried to reduce the mesh size, increasing the number of division.
B. I am using Bottom Up Approach, Initially I use the Edge meshing and then Mesh Meshing.
C. I check if there is extra face or volume created in Space-claim. But Error Doesn't change.
D. I have multi body which I have merge using shared topology in Space-claim. Do you I think there is any issue.
E. My body is fluid volume extract.
Still I am getting similar error!
Old   September 2, 2020, 21:39
karachun's Avatar
I'm familiar only with DesignModeller, I do not use Spaceclaim.
Better to ask this question in Ansys meshing forum. Moreover you try to import mesh into Fluent but this is a CFX forum, not Fluent.
https://www.cfd-online.com/Forums/ansys-meshing/
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface Kryo OpenFOAM Meshing & Mesh Conversion 13 February 17, 2022 07:34
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
[snappyHexMesh] Snappyhex mesh: poor inlet mesh Swagga5aur OpenFOAM Meshing & Mesh Conversion 1 December 3, 2016 16:59
Dynamic mesh in Fluent to study tire in contact with road surface lihuang FLUENT 10 March 8, 2011 10:21
