a fatal error in cfx-solver
Old   September 6, 2006, 07:56
Default a fatal error in cfx-solver
Jason
| ERROR #002100048 has occurred in subroutine SU_BNEXT. Message: All vertices for a fluid domain lie on a boundary. The solver considers this to be a fatal error because control volume gradients cannot be calculated, leading to serious discretization error. | This error may arise for two-dimensional simulations when a free slip boundary condition is applied to the end planes. In this situation a symmetry condition should be applied to the end planes . | Execution is terminating. This error message can be bypassed by setting the expert parameter 'boundary vertex check = f'.
I simualte fluid in a thin board,error as above.Can someone give me some suggestion?
Old   September 14, 2006, 04:53
Default Re: a fatal error in cfx-solver
Fusion
You have a 1-cell thickness domain? Your lateral planes should be set to symmetry planes, otherwise the "CV gradients cannot be calculated", is it clear? F
CFX Solver Error.. manjuny CFX 0 June 15, 2010 21:25
desperate Fatal overflow in linear solver - transient kingjewel1 CFX 9 January 5, 2010 13:53
CFX Solver Memory Error mike CFX 1 March 19, 2008 07:22
CFX 5.7.1 PRE and solver won't start daniel CFX 1 January 20, 2006 10:09
problem in CFX solver about isolated volumes Yuan CFX 2 August 16, 2004 22:54
