September 28, 2011, 05:11 |
Appropriate convergence residuals?
Joe
Rep Power: 14 |
Dear all,
I am simulating thermal stratification in pipe. The problem is while the residual below 1e-5, the simulation result doesn’t match experiment result well. But if I enlarge the residual of the energy equation(for example 1e-4), I can get a similar result with experiment. Is anyone encounter the same situation with me. The problem is? Thanks in advance! |
September 28, 2011, 07:19 |
Rep Power: 143 |
You would have to post some results to show what is changing between the two convergence levels.
Also this may help: http://www.cfd-online.com/Wiki/Ansys..._inaccurate.3F |
September 28, 2011, 14:35 |
#3 | |
Just assume, if we get the right solution; with any mesh, time step and turbulence model, which is overlapping with experimental data, then there shouldn't be any need of latest research in CFD and even we wouldn't had this sort of discussion any more in CFD-ONLINE |
October 10, 2011, 08:25 |
Joe
Rep Power: 14 |
I had a vacation last week. Thanks for ghorrocks and Far 's reply. I'll have a try about your suggest.
Convergence | Centurion2011 | FLUENT | 48 | June 14, 2022 23:29 |
Convergence issue- residuals of continuity | s.garg | FLUENT | 4 | November 7, 2016 11:39 |
Force can not converge | colopolo | CFX | 13 | October 4, 2011 22:03 |
convergence and residuals | ebm | CFX | 2 | February 2, 2009 17:55 |
Convergence - scaled vs unscaled residuals | HS | FLUENT | 1 | November 7, 2005 05:45 |
