October 27, 2020, 03:55 |
Fatal overflow in linear solver.
M Firdaus Fajar Saleh
Rep Power: 5 |
Hello Everyone,
i got fatal error when i use 2 domain interface for outlet in Francis turbine. me and team are making new innovation about Francis turbine with 2 outlet flow. but when I use two outlet domain interface in different mesh of their draft tube I got Fatal overflow in linear solver. anyone have a solution? thanks before, fa |
October 27, 2020, 05:28 |
Gert-Jan
Rep Power: 27 |
Should not be a problem. Probably there is something wrong in your settings. Please share your output file.
October 27, 2020, 05:50 |
Output File
Rep Power: 5 |
OUTER LOOP ITERATION = 590 ( 1) CPU SECONDS = 1.636E+05 (6.334E+01) ---------------------------------------------------------------------- | Equation | Rate | RMS Res | Max Res | Linear Solution | +----------------------+------+---------+---------+------------------+ +--------------------------------------------------------------------+ | ERROR #004100018 has occurred in subroutine FINMES. | | Message: | | Fatal overflow in linear solver. | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | The ANSYS CFX solver exited with return code 1. No results file | | has been created. | +--------------------------------------------------------------------+ End of solution stage. +--------------------------------------------------------------------+ | Warning! | | | | After waiting for 60 seconds, 1 solver manager process(es) appear | | not to have noticed that this run has ended. You may get errors | | removing some files if they are still open in the solver manager. | +--------------------------------------------------------------------+ |
October 27, 2020, 06:04 |
Gert-Jan
Rep Power: 27 |
If you look on this forum, you will find that FINMES means "Final Message".
This brings us nothing. We need the complete output file. I read that the error occured at the first iteration. What did you change? What happened in the previous 590 iterations? |
October 27, 2020, 06:26 |
Rep Power: 5 |
first, i have 1 domain with 2 fluid model for outlet in left and right runner's turbine. but the result is weird. so I use two domain with 2 geometry. then I have try about 10th times but the solver still error like those message
October 27, 2020, 06:44 |
Output File
Rep Power: 5 |
OUTER LOOP ITERATION = 582 CPU SECONDS = 1.615E+05 ---------------------------------------------------------------------- | Equation | Rate | RMS Res | Max Res | Linear Solution | +----------------------+------+---------+---------+------------------+ | U-Mom | 0.97 | 7.8E-04 | 6.1E-02 | 1.0E-01 ok| | V-Mom | 0.99 | 2.1E-03 | 1.5E-01 | 5.2E-02 OK| | W-Mom | 1.00 | 2.1E-03 | 1.5E-01 | 5.0E-02 OK| | P-Mass | 0.98 | 2.4E-04 | 8.8E-03 | 8.5 6.6E-02 OK| +--------------------------------------------------------------------+ | ****** Notice ****** | | A wall has been placed at portion(s) of an OUTLET | | boundary condition (at 39.7% of the faces, 47.3% of the area) | | to prevent fluid from flowing into the domain. | | The boundary condition name is: Outlet. | | The fluid name is: Fluid 1. | | If this situation persists, consider switching | | to an Opening type boundary condition instead. | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | ****** Notice ****** | | A wall has been placed at portion(s) of an OUTLET | | boundary condition (at 44.8% of the faces, 52.7% of the area) | | to prevent fluid from flowing into the domain. | | The boundary condition name is: Outlet 2. | | The fluid name is: Fluid 1. | | If this situation persists, consider switching | | to an Opening type boundary condition instead. | +--------------------------------------------------------------------+ +----------------------+------+---------+---------+------------------+ | H-Energy | 1.01 | 8.7E-04 | 1.0E-01 | 5.5 5.1E-02 OK| +----------------------+------+---------+---------+------------------+ | K-TurbKE | 0.99 | 4.7E-04 | 8.2E-02 | 5.5 2.0E-02 OK| | E-Diss.K | 1.00 | 9.8E-04 | 1.1E-01 | 7.5 2.8E-03 OK| +----------------------+------+---------+---------+------------------+ ================================================== ==================== OUTER LOOP ITERATION = 583 CPU SECONDS = 1.618E+05 ---------------------------------------------------------------------- | Equation | Rate | RMS Res | Max Res | Linear Solution | +----------------------+------+---------+---------+------------------+ | U-Mom | 0.99 | 7.8E-04 | 6.8E-02 | 1.1E-01 ok| | V-Mom | 1.00 | 2.1E-03 | 1.4E-01 | 5.2E-02 OK| | W-Mom | 0.99 | 2.1E-03 | 1.6E-01 | 5.1E-02 OK| | P-Mass | 0.96 | 2.3E-04 | 9.1E-03 | 8.5 6.6E-02 OK| +--------------------------------------------------------------------+ | ****** Notice ****** | | A wall has been placed at portion(s) of an OUTLET | | boundary condition (at 39.7% of the faces, 47.3% of the area) | | to prevent fluid from flowing into the domain. | | The boundary condition name is: Outlet. | | The fluid name is: Fluid 1. | | If this situation persists, consider switching | | to an Opening type boundary condition instead. | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | ****** Notice ****** | | A wall has been placed at portion(s) of an OUTLET | | boundary condition (at 44.8% of the faces, 52.7% of the area) | | to prevent fluid from flowing into the domain. | | The boundary condition name is: Outlet 2. | | The fluid name is: Fluid 1. | | If this situation persists, consider switching | | to an Opening type boundary condition instead. | +--------------------------------------------------------------------+ +----------------------+------+---------+---------+------------------+ | H-Energy | 0.98 | 8.5E-04 | 1.0E-01 | 5.5 5.1E-02 OK| +----------------------+------+---------+---------+------------------+ | K-TurbKE | 1.01 | 4.8E-04 | 5.1E-02 | 5.5 2.1E-02 OK| | E-Diss.K | 1.06 | 1.0E-03 | 1.3E-01 | 7.5 3.0E-03 OK| +----------------------+------+---------+---------+------------------+ ================================================== ==================== OUTER LOOP ITERATION = 584 CPU SECONDS = 1.621E+05 ---------------------------------------------------------------------- | Equation | Rate | RMS Res | Max Res | Linear Solution | +----------------------+------+---------+---------+------------------+ | U-Mom | 1.02 | 7.9E-04 | 7.7E-02 | 1.0E-01 ok| | V-Mom | 0.99 | 2.1E-03 | 1.5E-01 | 5.2E-02 OK| | W-Mom | 1.00 | 2.1E-03 | 1.7E-01 | 5.0E-02 OK| | P-Mass | 1.04 | 2.4E-04 | 1.3E-02 | 8.5 6.5E-02 OK| +--------------------------------------------------------------------+ | ****** Notice ****** | | A wall has been placed at portion(s) of an OUTLET | | boundary condition (at 39.7% of the faces, 47.3% of the area) | | to prevent fluid from flowing into the domain. | | The boundary condition name is: Outlet. | | The fluid name is: Fluid 1. | | If this situation persists, consider switching | | to an Opening type boundary condition instead. | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | ****** Notice ****** | | A wall has been placed at portion(s) of an OUTLET | | boundary condition (at 44.8% of the faces, 52.7% of the area) | | to prevent fluid from flowing into the domain. | | The boundary condition name is: Outlet 2. | | The fluid name is: Fluid 1. | | If this situation persists, consider switching | | to an Opening type boundary condition instead. | +--------------------------------------------------------------------+ +----------------------+------+---------+---------+------------------+ | H-Energy | 1.02 | 8.7E-04 | 8.7E-02 | 5.5 4.9E-02 OK| +----------------------+------+---------+---------+------------------+ | K-TurbKE | 1.00 | 4.8E-04 | 6.3E-02 | 5.5 1.9E-02 OK| | E-Diss.K | 0.97 | 1.0E-03 | 8.8E-02 | 7.5 2.9E-03 OK| +----------------------+------+---------+---------+------------------+ ================================================== ==================== OUTER LOOP ITERATION = 585 CPU SECONDS = 1.624E+05 ---------------------------------------------------------------------- | Equation | Rate | RMS Res | Max Res | Linear Solution | +----------------------+------+---------+---------+------------------+ | U-Mom | 1.02 | 8.1E-04 | 7.1E-02 | 1.0E-01 ok| | V-Mom | 1.00 | 2.1E-03 | 1.8E-01 | 5.1E-02 OK| | W-Mom | 1.01 | 2.1E-03 | 1.5E-01 | 5.0E-02 OK| | P-Mass | 1.01 | 2.4E-04 | 1.0E-02 | 8.5 6.5E-02 OK| +--------------------------------------------------------------------+ | ****** Notice ****** | | A wall has been placed at portion(s) of an OUTLET | | boundary condition (at 39.7% of the faces, 47.3% of the area) | | to prevent fluid from flowing into the domain. | | The boundary condition name is: Outlet. | | The fluid name is: Fluid 1. | | If this situation persists, consider switching | | to an Opening type boundary condition instead. | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | ****** Notice ****** | | A wall has been placed at portion(s) of an OUTLET | | boundary condition (at 44.8% of the faces, 52.7% of the area) | | to prevent fluid from flowing into the domain. | | The boundary condition name is: Outlet 2. | | The fluid name is: Fluid 1. | | If this situation persists, consider switching | | to an Opening type boundary condition instead. | +--------------------------------------------------------------------+ +----------------------+------+---------+---------+------------------+ | H-Energy | 1.00 | 8.7E-04 | 6.2E-02 | 5.5 5.3E-02 OK| +----------------------+------+---------+---------+------------------+ | K-TurbKE | 0.99 | 4.7E-04 | 4.9E-02 | 5.5 2.2E-02 OK| | E-Diss.K | 0.98 | 9.9E-04 | 1.4E-01 | 7.5 2.9E-03 OK| +----------------------+------+---------+---------+------------------+ ================================================== ==================== | Timescale Information | ---------------------------------------------------------------------- | Equation | Type | Timescale | +----------------------+-----------------------+---------------------+ | U-Mom-Draft Tube | Auto Timescale | 1.59155E-03 | | V-Mom-Draft Tube | Auto Timescale | 1.59155E-03 | | W-Mom-Draft Tube | Auto Timescale | 1.59155E-03 | | U-Mom-Runner | Auto Timescale | 1.59155E-03 | | V-Mom-Runner | Auto Timescale | 1.59155E-03 | | W-Mom-Runner | Auto Timescale | 1.59155E-03 | | U-Mom-Spiral | Auto Timescale | 1.59155E-03 | | V-Mom-Spiral | Auto Timescale | 1.59155E-03 | | W-Mom-Spiral | Auto Timescale | 1.59155E-03 | +----------------------+-----------------------+---------------------+ | H-Energy-Draft Tube | Auto Timescale | 1.59155E-03 | | H-Energy-Runner | Auto Timescale | 1.59155E-03 | | H-Energy-Spiral | Auto Timescale | 1.59155E-03 | +----------------------+-----------------------+---------------------+ | K-TurbKE-Draft Tube | Auto Timescale | 1.59155E-03 | | E-Diss.K-Draft Tube | Auto Timescale | 1.59155E-03 | | K-TurbKE-Runner | Auto Timescale | 1.59155E-03 | | E-Diss.K-Runner | Auto Timescale | 1.59155E-03 | | K-TurbKE-Spiral | Auto Timescale | 1.59155E-03 | | E-Diss.K-Spiral | Auto Timescale | 1.59155E-03 | +----------------------+-----------------------+---------------------+ |
October 27, 2020, 16:34 |
Rep Power: 143 |
I trust you have covered the basic stuff discussed in the FAQ: https://www.cfd-online.com/Wiki/Ansy...do_about_it.3F
October 28, 2020, 02:36 |
Rep Power: 5 |
fyi guys. i have fix this problem using inflation on meshing.
thanks before, and thanks for helping me ^^ |
October 28, 2020, 04:32 |
Rep Power: 143 |
OK, that's great. But normally refining the mesh makes convergence harder, not easier, so do not think this is always the solution to this problem. Your original mesh probably had some really poor quality elements.
October 28, 2020, 04:47 |
Gert-Jan
Rep Power: 27 |
I agree with Glenn. A fatal overflow, at the first iteration is not cause by presence or absense of inflation. Probably it has to do with your settings e.g. BC, or interfaces settings.
Nevertheless, success with your project. |
cfx & fluent |
Optimal tolerance and variables scaling settings | 4513645ygq | Main CFD Forum | 0 | July 28, 2020 08:56 |
Fatal overflow in linear solver error. Why? | zaidun | CFX | 7 | August 11, 2016 05:59 |
2nd Order Convergence Problem for 3D Airfoil | turkmengokce | OpenFOAM Running, Solving & CFD | 1 | September 10, 2015 07:20 |
2D isothermal cylinder not converging | UPengineer | OpenFOAM Running, Solving & CFD | 7 | March 13, 2014 05:17 |
how to modify fvScheme to converge? | immortality | OpenFOAM Running, Solving & CFD | 15 | January 16, 2013 13:06 |
