interpolate transient solution into one domain only
Old   October 30, 2020, 06:59
Default interpolate transient solution into one domain only
sortik is on a distinguished road
let's say I have two domains. Domain1 and Domain2. I have result file from the first simulation. I want to use the result file to interpolate results into domain 1 and want to be able to initialize domain2 with my value for the second simulation.
I specified initial values file in the execution control, left Initial values control unchecked, didn't use interpolation mapping and disabled domain initialization for the domain 1. I left domain2 with domain initialization checked with automatic value however ansys seems to ignore this and interpolate results into both domains.
Mesh is the same in both simulations
What are my options here? Am I doing something wrong or it is just not possible to do it this way.
Thanks in advance
sortik is offline   Reply With Quote
Old   October 30, 2020, 17:11
ghorrocks is a jewel in the roughghorrocks is a jewel in the roughghorrocks is a jewel in the roughghorrocks is a jewel in the rough
I don't understand your question. Are domains 1 and 2 in different locations? Then of course you can't interpolate one onto the other. Or do they lie on top of each other? Then why have you done that?
If you want to do more sophisticated initial conditions you can use a CEL function calling an interpolation routine, or calling a user fortran function.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   October 30, 2020, 17:26
Imagine a cube that is cut in a half (each half is one solid). Bottom solid is domain1 and upper solid is domain2. domain 2 has some initial conditions at 0s. after simulation is finished I need to do another simulation but this time I have to interpolate result from domain1 into domain1 and domain2 has to start with some initial conditions thus I do not want to interpolate result from domain2 into domain2 but i want to use initial conditions that I had specified.
You mentioned that I can call initialization routine. Is this even possible during simulation? for example Can I call init routine at step number 20?
My case is that I have cyclic process where upper half of the cube starts at certain temperature (whole volume has for instance 500C) every 100 seconds. I need to simulate heat transfer into the bottom half and need result for first 10 cycles. So at each cycle bottom half is at different condition but upper half has always 500C at each start
Old   October 30, 2020, 17:36
In my experience on this forum, about 90% of unusual requests like this are actually XY problems (https://en.wikipedia.org/wiki/XY_problem). Please explain what you are trying to model and what you are trying to achieve with this model.
Old   October 30, 2020, 17:47
I think I described it but maybe too complicated because english is not my mother tongue and it is difficult for me to precisely express my thoughts.
So once again and simple. My transient simulation will have 200 seconds and after every 20 seconds I need to initiliaze one domain with temperature of 500C. The other domains cannot be initialized.
Old   October 30, 2020, 17:53
Or the other question was that if I want to use previous result file for the initialization and want to exlude one domain from that interpolation and use Domain initiazation option instead
Old   October 30, 2020, 22:13
You can control which domains get initialised by setting the initial conditions tab on the domain in CFX-Pre.
Yes, you have said that you have a transient simulation and every 20s you initialise one domain to 500C. But these details are vague and I have no idea what they mean. So what is this device? What resets it to 500C? How does it reset it? And what are you trying to learn by doing this simulation?
For instance, if you want to reset your domain to 500C each 20s a far easier way of doing it is by using a source term. This is what I mean by an XY problem - it is likely that your initial condition setting proposal is not the best way of doing it. But for us to suggest a better way I have to know what you are doing and why.
Old   October 31, 2020, 06:43
Ok I get it. Sorry for my vague explanation.
this is the process:
it is glass pressing into cast iron mold. The process starts when mold has ambient temperature. at first mold is heated for 10 seconds up to 400 C. after 10 seconds gob of molted glass drops into the form (glass temperature is around 1400 C). The glass stays in the form for 20 seconds. after 20 seconds glass is removed from the form and process idles for another 20 seconds (form is cooled by natural convection). The process starts again.
My aim is to simulate temperature profile in the form and also in the glass.
I can simulate one cycle because initial conditions are: form has 25C and glass has 1400C.
But I don't knnow how to simulate the second cycle where the form is heated from the previous cycle but glass has again 1400C (initial conditions).
I tried using .res file from the first simulation but the problems is that ansys interpolates results into the form domain and glass domain even thought Glass domain has domain initialization checked. Ansys just ignores it and uses temperature profile from the first simulation result.
You suggested using the source but I am afraid that is not possible because it would mean that glass would have 1400 C the whole time.
There is an interface between the glass and the form so after the initial condition for the glass it is rapidly cooled by the heat transfer into the form domain.
I need to do at least +-10 cycles because after that number of cycles the form will be heated to the desired temperature.
I hope you understand my problem right now.
If ansys would not interpolate results into the glass domain and use domain initialization instead all would be fine.
Old   October 31, 2020, 06:59
If you just want to set the glass to a constant 1400C every 40s (or 20s or whatever the period is) then just use a source term. It is very simple. You can set the temperature to 1400C using a source term like:
S(T) = -C(T-1400[C])
with a source term coefficient of -C
Set C to be large relative to the other parameters.
To make it act every 40[s] then multiply it by a function which is zero most of the time and 1 for a short period every 40s (but at least one time step long). You can do this with an interpolation function, but more elegantly using the mod function, something like:
t_in_cycle = mod(t,40[s])
f = if(t_in_cycle<0.1[s],1,0)
This will turn the function on for 0.1s every 40s, and repeat this pattern every 40s forever.
and modify your source term to:
S(T) = -C(T-1400[C]) * f
Now the function f turns the source term on and off.
Easy. And you don't need to do any weirdness with the initial conditions at all.
Old   October 31, 2020, 08:19
thank you for your answer. I really appreciate it.
Will this source term "heat" the domain up to 1400 C within 0.1s? I am asking because the glass domain will have some temperature profile and the average temperature in the domain before I turn the source on will be around 100 C.
I am trying to set this up so I can test it but the source term unit has to be in [W m^-3] and if I use -C(T-1400[C]) where C=50000[W m^-3] i get this error message:
Expression resolves to invalid units ('kg m^-1 s^-3 K') in value set for parameter 'Source' in object '/FLOW:Flow Analysis 1/DOMAIN:Glass/SUBDOMAIN:Subdomain 1/SOURCES/EQUATION SOURCE:energy'. Expected units: 'W m^-3'.
Old   October 31, 2020, 08:59
this is how it's set
and this is the temperature profile of the glass during simulation
I can see that it does something but the effect is too low and the formula depends on temperature difference in the domain. If the difference is low the source is also low and I think that 0.1s for its effect is too short.
I am worried that it wont be possible to do it this way
Old   October 31, 2020, 21:37
Then your simulation is not converged or your C factor is too small.
No, it does not.
Then make it longer! As I said in the previous post, the time it is applied for has to be long enough to get at least one time step every time. You have not provided many details of what you are doing, so I had to guess a time size. If I guessed too small then make it bigger!
I have been doing CFD for almost 30 years. I know what I am talking about.
You just have some problems with the way you implemented it. It will work fine when you implement it correctly.
One problem I can see straight away is that you have not included a source term coefficient, like I said you needed. This will make convergence MUCH harder. Include the source term coefficient and convergence will be much better.
And a small correction to my post #9: The source term coefficient should be -C*f now that we have added the "f" function. Read the documentation if you want to know why.
result interpolation
Solution domain modification of results maksay FLUENT 0 September 15, 2020 04:44
Convergence Centurion2011 FLUENT 47 February 12, 2020 12:18
Turbomachinery Mass imbalance sheaker CFX 12 September 5, 2019 09:09
Can CFX model periodic heat transfer problem Ethan_Sparkle CFX 41 June 14, 2017 08:22
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
