October 6, 2006, 00:58 |
MFX: weired force transfer from cfx to ansys
I'm using cfx 10.0 and ansys multiphysics 10.0 to simulate a fluid-structure interaction problem. The model is very simple, just a flat panel with fluid flows above it. cfx run in transient mode, ansys run in steady mode.
cfx solver run first and then ansys. after first cfx run, the pressure on panel should be 1 atm (101325Pa), and force 101325N (the panel is 1x1 in gemotry), it does right. then the pressure load tranftered to ansys, but after reviewing ansys output file, I find the force is 0.10133E+7, which is 10 times to cfx load. It's WRONG, because the load relax factor has been set to 1, these two force should be equal. has anyone found this problem? |
October 6, 2006, 12:34 |
Re: MFX: weired force transfer from cfx to ansys
Do you have a username / password to the CFX community site?
October 6, 2006, 12:37 |
Looking under the CFX technotes at example they given.
October 7, 2006, 03:08 |
I can't access to CFX community site now. Would you send me a copy of that example?
ANSYS Multi-physics and CFX coupling error | anujit | CFX | 3 | June 21, 2009 18:39 |
Exporting results from CFX to ANSYS ?? | sohail ahmed | CFX | 1 | December 20, 2007 01:10 |
Temperature transferring from CFX to ANSYS? | Se-Hee | CFX | 0 | November 28, 2006 05:56 |
ANSYS to acquire CFX | Fred | FLUENT | 0 | February 18, 2003 21:04 |
ANSYS to acquire CFX | Fred | Siemens | 0 | February 18, 2003 21:03 |
