error "specified procedure not found" CFX solver
Like Tree1Likes
  • 1 Post By ghorrocks
Old   November 14, 2020, 16:22
Question error "specified procedure not found" CFX solver
AMB
BOUALOUACHE is on a distinguished road
hello,
freinds please i need some help )
i want to simulate heat transfert in a rectangular cavity ,
one of the forces considered in the flow modeling needs a random coefficient during the simulation,
for that, i have used the integration of fortran with ansys method, using a subroutine to generate random numbers.
when i run the CFX solver i get a returned code 1 caused by an error #001100279 SUBROUTINE ERRACTION , specified procedure not found ( i have attached a screen shot)
so, am i in the right way to have the random coefficient for the force expression?.
how can i correcte this CFX solver error?
waitng for your answer ,
greetings
BOUALOUACHE is offline   Reply With Quote
Old   November 15, 2020, 05:28
Your screen shot suggests there is a problem with your fortran.
Remember that with CFX, one error will often lead to another, and then errors cascade from there. The only important error is the first one, as that is the one which caused the whole cascade. All the other errors can be ignored.
BOUALOUACHE likes this.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   November 15, 2020, 07:39
AMB
i'have used visual studio to generate the DLL file of the subroutine (which contains fortran libreries)
i understand that i have a problem with the DLL file ,so i'm working of the verification of the program and the dll file
Old   November 16, 2020, 07:53
Opaque will become famous soon enough
Have you verified the compiled subroutine, i.e. DLL is located in the path shown in the message?
Opaque is offline   Reply With Quote
Old   November 16, 2020, 09:27
AMB
the compilation was done with no errors,the error affiched is about hte opening of the dll file ,
i have attached a command line screenshot if it can helps for some explanation
Old   January 9, 2022, 12:56
Ahmed Ben
Bedda is on a distinguished road
Hi Boualouache,
Did you come up with a solution for your problem? I am currently facing the same issue as yours ("specified procedure not found").
Thank you for any help you can offer
Bedda is offline   Reply With Quote
[ANSYS Meshing] Icem generated mesh changing in cfx solver Mfaizan ANSYS Meshing & Geometry 6 May 2, 2016 03:37
CFX solver workspace & ourfile Problem wangy1767 CFX 1 January 9, 2013 09:38
Reynolds Number- CFX Solver Jwolf CFX 5 January 23, 2010 19:07
CFX SOLVER error !!! mehrdadeng CFX 3 November 23, 2009 16:42
CFX 5.5 Roued CFX 1 October 2, 2001 16:49
