Material properties for PP
Old   November 23, 2020, 08:32
Default Material properties for PP
Sara
Knowledge is on a distinguished road
Hi
For my simulation in CFX I need to specify the wall material to be of polypropylene PP. I need to specify PP's thermal properties, but I can not find them on the internet. Do you know a online database for materials where I can find molar mass, density, specific heat capacity, thermal expansion etc. for the material PP?
Thanks
Knowledge is offline   Reply With Quote
Old   November 23, 2020, 10:01
Gert-Jan
Gert-Jan will become famous soon enough
engineeringtoolbox
Gert-Jan is offline   Reply With Quote
Old   November 23, 2020, 14:28
Sara
Originally Posted by Gert-Jan View Post
engineeringtoolbox
Not all the information is there.
Old   November 23, 2020, 15:25
Gert-Jan
Maybe you should try a little harder:
Density: https://www.engineeringtoolbox.com/d...ls-d_1652.html
Cp: https://www.engineeringtoolbox.com/s...ity-d_391.html
And you don't need Molar mass, nor thermal expansion for CFD.
Btw, you'll never find a molar mass for PP since it depends on the polymerisation degree.
Old   November 24, 2020, 15:58
Sara
Thank you.
material, properties
material properties of solid parts are constant ? oozcan FLUENT 0 August 2, 2016 06:04
Simple piston movement in cylinder- fluid models arun1994 CFX 4 July 8, 2016 02:54
[Other] Material properties in multi region foam and refining mesh for each region mukut OpenFOAM Meshing & Mesh Conversion 2 October 7, 2013 02:08
Material Properties in COMSOL for different domains with different physics TryMyBest COMSOL 0 March 5, 2013 08:23
Vaiable Material properties Pialisen FLUENT 2 November 29, 2006 13:12
