October 27, 2006, 08:54 |
ICEM problem
Hi all,
I'm simulating a wind tunnel test for a flow over hydrofoil. After making the mesh, I see mesh elements penetrate the foil with a small hole in the mesh around the foil end. Where is the problem? The foil has a top, bottom and side surfaces. Why the mesh inside the foil not around? Any guides are welcome. Ali |
October 27, 2006, 10:03 |
Re: ICEM problem
If the top and bottom surfaces are very close, the projection algorithm in tetra may get them mixed up. To prevent this, define the top and bottom surfaces as a "thin cut". See the documentation for how to do this.
-Robin |
October 27, 2006, 10:31 |
Thanks Robin
Thanks Robin That's very helpful and fast.
Ali |
ICEM - strange linking problem | RodriguezFatz | ANSYS Meshing & Geometry | 3 | October 25, 2011 03:25 |
[ANSYS Meshing] Problem with Icem Script | Krish | ANSYS Meshing & Geometry | 0 | October 18, 2011 12:10 |
[ICEM] Problem while improting Solidworks Part file or Acis File into ICEM CFD | venki1130 | ANSYS Meshing & Geometry | 0 | October 13, 2011 13:04 |
ICEM boundary condition problem | Martin_D | ANSYS Meshing & Geometry | 2 | February 14, 2011 10:20 |
Icem to FLUENT problem | Babak | FLUENT | 0 | June 10, 2010 17:14 |
