Turbo Mode for Transient Results
Old   December 10, 2020, 09:27
Default Turbo Mode for Transient Results
Michael Hopfinger
karwendel is on a distinguished road
I am calculating the transient performance of 1.5-stage (IGV, rotor, stator) axial compressor.
For my steady-state cases, I always apply the turbo mode and export numerous radial distributions. This is done using a cse/perl script.
Now, I am running unsteady simulations and export for every transient timestep a partial *.trn file. Since my mesh is quite fine and I want to save resources, I only export selected quantities which gives me *.trn and not *full.trn files.
Finally, I want to export the same radial distributions as for my steady-state case for all my *.trn in turbo mode. Somehow, this doesn't work. The *.trn file does not get loaded.
Is it possible to assess trn-files in turbo mode or do you need a full_trn-file? Of course, all variables, that I want to see in the post processing, I selected in pre.
Thank you.
karwendel is offline   Reply With Quote
Old   December 15, 2020, 22:11
Zhifeng Yan
Zhifeng is on a distinguished road
I guess you can check if the radial distribution you want is based on some variables which are not saved in the transient simulation. My experience is: in the Linux system, it reports an error, but in the Windows system, it doesn't work.
Sincerely
Zhifeng
Zhifeng is offline   Reply With Quote
bad heat transfer results with low y+ me45 OpenFOAM Running, Solving & CFD 0 April 29, 2020 11:56
Error Interpolating Results onto New Mesh nammeh CFX 1 March 26, 2019 12:08
Save Results automatically by APDL Command ansyxyz ANSYS 1 June 5, 2018 08:16
Different results from Batch and GUI mode h0rst ANSYS 0 July 20, 2017 01:52
Different results in parallel/serial mode kpax OpenFOAM Running, Solving & CFD 1 October 22, 2012 06:22
