High Local mach number for sub sonic flow
Old   November 2, 2006, 10:23
Default High Local mach number for sub sonic flow
kali
I have a rotor stator model. This is a subsonic model using RNG KE. But I have observed that locally the flow shows high mach number(2.7) at the exit of a narrow rotor stator gap. Essentially the flow comes out as a jet. Although CFX warns to change to max contuinty loop 2, still the model continues to run and gets converged. I suspect the mesh locally. But looks pretty decent(ICEM quality 0.4 determinant and 18 deg angle). Can someone through some lights on the issue including the grid..
Thanks in advance, Kali
Boundary conditions low Mach number flow lost.identity Main CFD Forum 0 November 28, 2010 04:44
Large Eddy Simulation with too high Mach number Roland R CFX 4 November 25, 2010 16:43
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
Difficulties in solving a high Reynolds number Flow? wowakai Main CFD Forum 10 December 29, 1998 13:46
"The high Reynolds number flow is not difficult to compute, the problem is we simply don't know how. wowakai Main CFD Forum 1 November 11, 1998 10:24
