Ansys CFX overpredicting drag?
Like Tree2Likes
  • 2 Post By ghorrocks
Old   December 20, 2020, 14:14
Default Ansys CFX overpredicting drag?
Nineties123 is on a distinguished road
Hi, I'm trying to replicate experimental data for a NACA 2415- using data from the Abbott and Von Doenhoff book- and for some reason, even though I can get to within about 10% of the lift, Ansys CFX is consistently overpredicting my drag by a ridiculous amount- around 200% in some cases.
I'm debating making my inflation larger- is that likely to help? I suspect it may be to do with the viscous drag.
I am quite new to using Ansys, so any help would be much appreciated.
Nineties123 is offline   Reply With Quote
Old   December 20, 2020, 14:22
Kira
aero_head is on a distinguished road
What is your mean value for Y+?
The Y+ mean value should be near 1. Don't worry about low values for Y+ at the leading edge, it is more important to have the correct value (i.e. 1) of Y+ from around 1/4 chord to 100% of chord.
As well, what turbulence model are you using for your simulation?
ETA: I have heard that CFD almost always overpredicts the drag of airfoils, so just be aware of that. I think the best it can do is get the value to within ~20%-30%. It is very good at predicting lift (pressure forces) but bad predicting drag (viscous forces).
Last edited by aero_head; December 20, 2020 at 19:48. Reason: Added more info on CFX and drag prediction
aero_head is offline   Reply With Quote
Old   December 20, 2020, 14:52
ETA: I have heard that CFD almolst always overpredicts the drag of airfoils, so just be aware of that. I think the best it can do is get the value to within ~20%-30%. It is very good at predicting lift (pressure forces) but bad predicting drag (viscous forces).
Hi, I used a y+ calculator to calculate my first layer thickness and used a y+ of 1. When I looked at my y+ contour along the aerofoil surface it was mostly 1 up to towards the trailing edge. The maximum was 1.6.
I am also using a Shear Stress Transport turbulence model.
Old   December 20, 2020, 16:31
Have you gone through the issues listed on the FAQ: https://www.cfd-online.com/Wiki/Ansy..._inaccurate.3F
Some key ones for this case:
* Is your mesh fine enough?
* Is it converged enough?
* Is your turbulence model appropriate for the condition you are modelling?
* Is your boundary conditions far enough upstream and downstream?
* Is your side boundaries far enough away to act as far fields?
* Do you have turbulence transition?
* Do you have separations?
I do not agree with aero_head, you can get drag predicted very accurately if you carefully validate your model (at least in the attached flow regimes). The turbomachery and aerospace industries routinely get extremely accurate results for airfoil modelling - but they have also very carefully validated their simulation procedures. But getting accurate drag is much harder than getting accurate lift.
karachun and aero_head like this.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
ghorrocks is online now   Reply With Quote
Old   December 20, 2020, 16:46
Kira
Good to know, thanks for clearing that up ghorrocks!
Old   December 20, 2020, 18:52
Lorenzo Galieti
LoGaL is on a distinguished road
I agree whit what has been said before. Actually, for NACA airfoils, you can surely get correct results for pre-stall angle of attack. TBH 200% is too off, I think there's a not so smart mistake somewhere
LoGaL is offline   Reply With Quote
Old   December 21, 2020, 13:52
Hi, I've just noticed that on my y+ contour, the y+ value appears to be a lot lower than 1 at the leading edge and increases up to 1.6 at the trailing edge and near the quarter chord. How do I fix this?
Old   December 21, 2020, 13:54
Hi, what would you suggest I do to fix it? I have used a y+ calculator to find the first layer thickness but on my y+ contour, the y+ value appears to be quite a bit lower than 1 at the leading edge and around 1.6 at the half chord to leading edge.
Alternatively I am possibly debating increasing the number of inflation layers.
I am currently using a SST transition model, for context.
Old   December 21, 2020, 16:53
Why are you requiring y+=1? What are you doing which requires that?
Your simulation will not fail if you depart slightly from y+=1. I would recommend you do a mesh sensitivity study where you take your existing mesh and compare it against a y+=0.5 and y+=2.0 mesh to see if it actually makes a difference in your case. This will tell you if it makes any difference.
Old   December 22, 2020, 06:42
Lorenzo Galieti
if you get y+ = 1.6 it is pretty fine. Concerning increasing the number of inflation layers, what are you imposing, smooth transition or first layer thickness? If you impose smooth transition, yes, just increase the layers by 2-3 and you drop below 1 almost for sure. SST will work fine so long as your Y+ is around 1, but you won't anyways get anything wrong if you get Y+= 2 somewhere
Concerning the transition model, I have no experience with it, but if your reynolds number is high enough, stick with the normal SST, not the transition one.
What I am saying is that, considering that you are 200% off the expected Cd, you must have done some more trivial mistake, e.g. uncorrect geometry, wrong fluid properties and so on. The point is that it is not surprising you match the Lift coefficient, because for most of the bodies in attached regime, Cl = 2pi*alfa
Mind posting a pic of the mesh and some velocity contour around the airfoil?
Old   December 22, 2020, 07:18
Hi, I am currently struggling to open Ansys but luckily I recorded everything I have done.
I used JavaFoil with 101 points and modified for a closed trailing edge for the NACA 2415 geometry.
Below is a link to a Google Doc file where I have included relevant images.
https://docs.google.com/document/d/1...it?usp=sharing
The contours and streamlines are for where I tested at 3 degrees AoA with conditions for a Reynolds number of 6*10^6 with conditions at altitude 2500m. I have also added the domain we are currently using (in combination with the mesh it gave us a 2% error difference on Cl and 50% difference on Cd at 0 AoA, however this swiftly changed to a 17.75% error on Cl and 37.39% error on Cd when I increased the AoA to 3 degrees)
The following are all the Mesh settings I used:
DISPLAY
Display Style: Use geometry Setting
DEFAULTS
Physics Preference: CFD
Solver Preference: CFX
Element Order: Linear
Element Size: Default
SIZING
(all of this was left as the default)
Use Adaptive Sizing: No
Growth Rate: Default
Max Size: Default
Mesh Defeaturing: Yes (this was on as a default)
- Defeature Size: Default
Capture Curvature: Yes
Curvature Mi...: Default
Curvature Nor...: Default
Capture Proximity: No
QUALITY (all of these were left as default)
Check Mesh Quality: Yes, errors
Target Skewness: Default (0.900000)
Smoothing: Medium
Mesh Metric: None
INFLATION
Use Automatic Inflation: All faces in chosen named selection
Named Selection: Wall (my aerofoil)
Inflation Option: First Layer Thickness
First Layer Height: 7.53e-06 (this number was taken from entering the altitude conditions and chord length of 1.626m into a y+ calculator for y+ of 1)
Maximum Layers: 15
Growth Rate: 1.3
Inflation Algorithm: Pre
View Advanced Options: Yes
(only change was Maximum Angle to 180 degrees)
ADVANCED and STATISTICS all left alone
I then inserted a Sizing
SCOPE
Scoping Method: Geometry Selection
Geometry selected was the entire domain
DEFINITION
Suppressed: No
Type: Body of Influence
Bodies of Influence: (Selected the internal domain)
Element Size: 1e-2
ADVANCED
Growth Rate: Default (1.2)
Any help would be much appreciated.
Old   December 22, 2020, 09:24
Lorenzo Galieti
Hi, from all the settings I can't guess much, I just wanna see this pictures of mesh and flow.
Only thing I can say is that if you wanna lower your y+, decrease first thickness value. Growth Rate 1.3 is garbage, aim for 1.2 or 1.15
But again, if you get so grossly wrong results, I repeat that you have done some bad mistake. Show me pictures of this mesh pls
Parallel Computing for ANSYS CFX R17 Noco CFX 7 January 17, 2018 16:14
A CFX-POST error (ver 14.5.7) wangyflp88 CFX 2 July 22, 2017 00:17
How to use ANSYS CFX to get the drag coefficient? victorzcc CFX 12 October 1, 2015 05:30
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
drag in cfx (important) deus CFX 2 July 8, 2008 21:50
