Visualizing tip leakage vortex core
Old   January 7, 2021, 04:16
Default Visualizing tip leakage vortex core
Julian121 is on a distinguished road
I would like to show tip leakage vortex core for a rotor with tip clearance.
I used streamline at a surface defined at 99% span corresponds to the halfway of tip clearance height but it shows all streamline coming over the tip clearance. Is there a way to show just the tip leakage vortex?
Should I use particle tracking for this purpose?
Julian121 is offline   Reply With Quote
Old   January 7, 2021, 04:58
You use particle tracking when you want to track particles, not when you want to visualise vorticies. So that is a no.
There are some additional variables in CFD-Post which can help in visualising vorticies. Have a look at the vortex core variables.
Your plane shows that all the flow at 99% span goes straight through and does not participate in the tip vortex. So try another % span. Also try seeding the streamlines at points just behind the tip where you think the vortex will be present. You just need to experiment with some seeding locations until you get it right.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
3D vortex panel method - wing tip and Kutta problems with elliptic wing maaiana67 Main CFD Forum 11 February 25, 2020 22:09
Visualizing Wake using Vortex Core Derived Part hwsv07 STAR-CCM+ 1 May 26, 2015 06:53
solving a conduction problem in FLUENT using UDF Avin2407 Fluent UDF and Scheme Programming 1 March 13, 2015 03:02
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
creating vortex core line aay023 Main CFD Forum 0 September 15, 2010 22:49
