November 18, 2006, 04:38 |
How can I make an interpolated function?
Dear All,
I am trying to make the heat transfer coefficient function, h(T), with respect to T. I have some sampled data sets as follows: T:: 280 290 300 350 400 h(T):: 2 7 8 12 14 Here, I'd like to make an interpolated function of which name is 'myH.' Where can I setup this kind of function and how can I use it? Many Thanks, Se-Hee |
November 19, 2006, 17:19 |
Re: How can I make an interpolated function?
This is a CEL 1-d interpolation expression. It is described in the documentation. Glenn Horrocks |
November 20, 2006, 03:23 |
Dear Mr. Glenn,
Thanks for your comments. I have built my own interpolated function followed by your guide as follows: 1) In CFX-Pre, Create/User function 2) My function name is 'myHCoeff' 3) Interpolation, One dimensional 4) Input data set: Temperature .vs. heat transfer coefficient 5) OK And when I use this function as boundary condition, how can I express the function? There were some errors to express my defined function when I try to use it. My expression was 'myHCoeff(T).' Is it incorrect? Many thanks, Se-Hee |
November 20, 2006, 11:52 |
What were the errors?
November 22, 2006, 19:08 |
Re: Error Message
The error message is as follows:
The variable 'T' referenced in parameter 'Heat Transfer Coefficient' in object '/Flow/Domain:Tank/Boundary:TankH/Boundary Conditions/Heat Transfer' does not have one of the required prefixes: phase or particle. Thanks for your help. Se-Hee |
November 24, 2006, 00:44 |
what is the prefixes: phase or particle?
As I mentioned in the above message, the error message was as follows:
The variable 'T' referenced in parameter 'Heat Transfer Coefficient' in object '/FLOW/DOMAIN:Tank/BOUNDARY:TankH/BOUNDARY CONDITIONS/HEAT TRANSFER' does not have one of the required prefixes: phase or particle. Here, could anyone please explain 'phase or particle'? I've tried many ways for resolving my problem, but I am still stuck at this stage. Se-Hee |
November 24, 2006, 06:32 |
Re: what is the prefixes: phase or particle?
If you have a multiphase flow, you need to add the phase/particle name before variables. Example:
Air Ideal Gas.Temperature Maybe this is what the error message is referring to? |
November 25, 2006, 07:30 |
Re: solved this problem with input profile.
Considering your comments, I have solved this problem at last as follows:
1. making profile instead of table 2. retype the function -> myHCoeff.hval(WireAl.T) where myHCoeff represents the function name of which I defined, hval represents the value of my function with reapect to temperature, and WireAl represents the material name of which I used in my simulation setup. Thanks for all kind comments. Se-Hee |
channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 13:06 |
ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 06:42 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
Problem with rhoSimpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 0 | February 28, 2008 06:51 |
[OpenFOAM] LibvtkFoamso | fred | ParaView | 2 | November 18, 2005 19:01 |
