Simulation Air Stream in a System with out Outlet Boundary
Old   January 22, 2021, 03:10
Default Simulation Air Stream in a System with out Outlet Boundary
Mey
MNMK is on a distinguished road
I would like to simulate a system which does not have any outlet. Infact, air as a media is sucked in my system through a fan, and again like a loop comes into the fan which probably should have a higher rotation speed. I would like to know how is the best model and boundary conditions for simulating this case in cfx?
regards,
MNMK is offline   Reply With Quote
Old   January 22, 2021, 03:44
I don't understand what you are trying to explain.
But the whole point of boundary conditions is you know the state of the fluid at that point, so you can specify it rather than modelling it. If you don't know the conditions at that point you cannot put a boundary condition there.
And a second point - if air goes into a domain and does not leave then air will accumulate in the domain. This will increase the temperature and/or pressure. It also means there is no steady state solution, so it must be a transient simulation.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   January 22, 2021, 04:23
Mey
Hi Ghorrocks,
First of all thank you because of your fast answer. You are absoloutly right. The fluid will accumulate and also its temperature and pressure will increase. Surely, it is a transient simulation. However, I do not understand whether it is possible to simulate a model with out Oulet boundary.
Old   January 22, 2021, 05:24
Gert-Jan
Gert-Jan will become famous soon enough
It sure is. Just give it a try.
I have performed calculations with a pump/fan with a closed outlet to determine the shut off head. This is possible in a transient calculation.
Gert-Jan is offline   Reply With Quote
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
Table bounds warnings at: END OF TIME STEP CFXer CFX 4 July 17, 2020 00:44
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field xiexing CFX 3 March 29, 2017 11:00
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
