Ansys CFX Problems running Supersonic
Old   January 28, 2021, 04:23
Default Ansys CFX Problems running Supersonic
Nineties123 is on a distinguished road
I'm having a problem trying to do a supersonic run for a NACA 2415 aerofoil on Ansys. I need to get results at Mach 1.2, 3 degrees AoA but every time the solver fails, giving me this error code: ERROR #004100018 has occurred in subroutine FINMES. | | Message: | | Fatal overflow in linear solver.
So far, I have tried:
- Running at Mach 1.3 instead (to see if the tangency of the shock was the problem. Ansys failed again)
- Increasing the top and bottom domain (again, to see if the tangency of the shock was the problem. Failed again)
- Increasing the Memory Allocation factor by 10% (failed again)
- Angling the flow instead of the aerofoil (using Cartesian velocity components at the inlet. Ansys failed)
- Angling the aerofoil (inlet, outlet and openings at top and bottom. Ansys failed again)
Any help would be much appreciated! I am quite new to Ansys.
Nineties123 is offline   Reply With Quote
Old   January 28, 2021, 10:51
Kira
aero_head is on a distinguished road
Did you run your simulation in single or double precision?
If single, switch to double and try running it again (it's a setting you select in solver manager, just select the check box to the right). It's right above the 'large problem' toggle.
Edited to add: I'm assuming this would be a transient simulation, so double precision would make a difference.
aero_head is offline   Reply With Quote
A Question about CFX Supersonic Flow Solving Theory Zhifeng CFX 1 March 27, 2021 09:23
FSI simulation in ansys cfx Arash67.m CFX 1 September 29, 2017 10:52
error about fsi in CFX and ANSYS WANGFIRE CFX 1 April 21, 2015 02:48
Statically Compiling OpenFOAM Issues herzfeldd OpenFOAM Installation 21 January 6, 2009 10:38
Exporting results from CFX to ANSYS ?? sohail ahmed CFX 1 December 20, 2007 02:10
