[Sponsors] | |||||
Daniel
Rep Power: 10 ![]() |
Hello everyone,
I am simulating a centrifugal compressor that I designed for a pipeline with methane. After meshing it with TurboGrid and setting up the Boundary Conditions and solver options in CFX I saw that the solver is placing walls because of backflow. But unusual here is, that it is not at the OUTLET but at the INLET! And the percentage is around 40 % which is not neglect able I would say. The efficiency values did converge as well as one additional monitor point. In one image the streamlines show such backflow near the inlet. My assumptions are that I either messed up the BC or the INLET is really to "short" and that I need to extend it much further. But extending a bit further only decreases the Wall % a bit (as a tried). So I ask myself whether this is correct to extend so long until no wall (or little %) will be placed. Also considering changing my INLET to an Opening is a question i ask myself whether this is the right way. (Sadly I can't fully increase mesh density because I only have a student version which limits mit to 512K nodes. But TG didn't show an mesh errors. Y+ might be a problem here.) Fluid: CH4 Ideal Gas BC INLET: Total Pressure - 20 [bar] Total Temperature - 293.15 [K] BC OUTLET: Massflow (Total to all sectors) - 200 [kg/s] If I should provide further information, let me know I hope someone has a hint for me ![]() Thank you very much! Daniel |
#2 | |
Rep Power: 146 ![]() ![]() ![]() ![]() |
Daniel
Then I will try that again and run the simulation with much longer inlet.
Thank you for the hint! |
Rep Power: 8 ![]() |
I would also try to modify the inlet to stabilize the flow
#5 | |
Rep Power: 34 ![]() |
Also, the % reported must be understood in the local context. Is it 40% of the mesh faces, or 40% inlet area? The latter is not tolerable; however, the former must be visualized in the post-processor to see what it means. Definitely, no backflow is ideal, but compromises are needed at some point.
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| [OLAFLOW] The OLAFLOW Thread | Phicau | OpenFOAM Community Contributions | 461 | June 6, 2025 17:44 |
| Inlet Profile Interpolation | dwstevens | SU2 | 1 | April 18, 2020 10:10 |
| K-Omega-Epsilon BCs for suction inlet | CFDBro | OpenFOAM Running, Solving & CFD | 0 | March 27, 2018 19:28 |
| multiphaseInterfoam non-constant inlet | kaaja | OpenFOAM Running, Solving & CFD | 4 | February 23, 2018 03:04 |
| Inlet Velocity in CFX | aeroman | CFX | 12 | August 6, 2009 19:42 |
