[Sponsors] | |||||
Rep Power: 6 ![]() |
Hi, I'm fairly new to Ansys CFX but currently attempting to simulate the supersonic Mach 1.2 flow over a subsonic aerofoil.
For some reason, I am able to get successful runs for 6, 9 and 12 degrees but not at 3- whenever I attempt it, I end up getting a "Fatal Overflow" message. I'm using the exact same mesh, domain and input values for all of the runs but for some reason it is only 3 degrees that appears to be failing- why could this be? |
Rep Power: 146 ![]() ![]() ![]() ![]() |
This question is a duplicate of your other thread: Problems running Supersonic
Please post responses on that thread.
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Problems running Supersonic | Nineties123 | CFX | 9 | February 6, 2021 20:20 |
| [OpenFOAM] Problems using paraFoam -touch after parallel run | arieljeds | ParaView | 9 | May 24, 2016 14:08 |
| _Parallel Run with two PCs problems_ | maysmech | OpenFOAM | 5 | October 20, 2012 03:14 |
| Working directory via command line | Luiz | CFX | 4 | March 6, 2011 21:02 |
| BIg BIg Problems....SUPERSONIC FLOW OVER A FLAT PL | edison | Main CFD Forum | 7 | October 11, 2005 10:34 |
