Error when definig two fluids
Like Tree12Likes
Old   February 10, 2021, 09:16
Gert-Jan
Gert-Jan will become famous soon enough
No. Remove the air domain. Only use the water domain.
How?:
In Pre, you now have a single Domain. I guess, this is referring to an assembly. This assembly consists of 2 mesh volumes: air and water.
Now, instead of referring to the assembly, refer to only to the mesh volume of water. Then the air will not be included in your calculation.
If Pre automatically creates a domain for the unused mesh (air) volume, go to the options where you enabled 'constant physics' before. There unclick 'Áutomatic Default Domain'. Then you can delete the obsolete air domain.
You end up with a single domain with only water. Then create a adiabatic free slip wall where you had the interface before.
aero_head likes this.
Gert-Jan is offline   Reply With Quote
two mixing compresible fluids solver ziemowitzima OpenFOAM Running, Solving & CFD 27 August 13, 2020 13:40
Mixing of two fluids (mashed potato and pigment-colour), singlephase or multiphase Zeljko CFX 7 February 23, 2018 08:58
micropolar fluids in flunet Shayan FLUENT 1 March 6, 2014 17:33
Differents fluids separated by wall phil FLUENT 0 January 18, 2007 03:43
turbulent mixing of two fluids ulrich bieder Main CFD Forum 2 October 9, 1999 17:15
