Change Timestep
Like Tree2Likes
  • 1 Post By AtoHM
  • 1 Post By ghorrocks
Old   February 12, 2021, 06:40
Default Change Timestep
Frank Weise
FrankW is on a distinguished road
I have a transient simulation where a parameter changes at a certain time. The whole thing runs with adaptive time steps. How can I reduce the time step in a defined manner shortly before changing the parameter in order to better capture the change.
FrankW is offline   Reply With Quote
Old   February 12, 2021, 10:13
M
AtoHM is on a distinguished road
I don't know for sure if its impossible, but I think it is. Wouldn't that defeat the purpose of adaptive timestepping?
However, you can still check the timestep cfx takes on its own, make a new simulation with that time step and then you can change it with an expression however you like.
aero_head likes this.
AtoHM is offline   Reply With Quote
Old   February 12, 2021, 20:35
Yes, AtoHM is right. It sounds like you want to change from adaptive time steps to your own time step as you approach the change. This means you need to stop the simulation and restart with adaptive time stepping removed and your defined time stepping used instead.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   February 15, 2021, 05:13
Frank Weise
Ok, thanks for the hints. I'll see how I can best implement it.
Convergence-behaviour when changing physical timestep in steady-state simulation stud-many ANSYS 0 October 28, 2019 11:30
[ICEM] How to change blocking around the mesh with change in design parameters? jainanup27 ANSYS Meshing & Geometry 0 June 11, 2019 17:39
Radiation interface hinca CFX 15 January 26, 2014 18:11
Timestep and Pressure Correction Relationship in SIMPLE rks171 Main CFD Forum 23 May 4, 2012 02:04
change timestep after a certain iteration number Sans CFX 5 June 3, 2007 06:17
